    Tab 5 screen flicker after firmware update
    11 Posts 3 Posters 5.5k Views 2 Watching
      sapphire
      Do you have the same problem that other people have had?
      https://community.m5stack.com/topic/7737/tab5-display-issue?_=1755381438444
      JomacJ 1 Reply Last reply Reply Quote 0
      • JomacJ Offline
        Jomac @sapphire
        @sapphire said in Tab 5 screen flicker after firmware update:
        No I don't, thats a completely different issue. On my display the picture is perfect other than the backlight flickers at about 5 or 6 Hz. Once I had downloaded and flashed the new firmware, this is when the issue started. Deleting the demo program and installing a couple of other progs makes no difference, the flickering is still there.
        I started out with absolutely nothing and still have most of it left.
          sapphire @Jomac
          @Jomac I also have this problem that happens from time to time I see it on the bottom right side
            sapphire @sapphire
            @sapphire http://192.168.1.61:5244/d/sd_card/mp4/WhatsApp Vidéo 2025-08-17 à 19.35.11_90e31b99.mp4?sign=AF_oijvWOMslZWSURfdyKx0T1D0PJ8FoIx0fS5Uevy0=:0
            JomacJ 1 Reply Last reply Reply Quote 1
            • JomacJ Offline
              Jomac
              I switched the Tab 5 on earlier this evening and this mystery fault seems to have cleared and I'm non the wiser. I must have turned the unit on and off thirty or so times and download several programs before with this fault present each time, so why has it cleared after leaving the Tab 5 alone for 24 hours?
              • JomacJ Offline
                Jomac @sapphire
                What is this link for?
                  sapphire @Jomac
                  @Jomac If you watch the video, I have this little defect that doesn't happen often (a flashing).
                  • JomacJ Offline
                    Jomac @sapphire
                    The link doesn't work for me
                    • kurikoK Offline
                      kuriko @Jomac
                      @Jomac Will this situation improve if I re-burn the old version of UiFlow2 firmware?
                      • JomacJ Offline
                        Jomac @Jomac
                        @Jomac said in Tab 5 screen flicker after firmware update:
                        Well I flashed the firmware several times and also flashed a couple of apps on M5Burner and nothing made any difference, everything just flickered so I switched off and left it for the night, next morning I was going to video the issue and when I switched on my Tab 5 again, the fault had cleared.
