使用ArduinoIDE编译Cardputer的示例代码,提示错误Error: missing data from bitq interface,如何解决?
Open On-Chip Debugger v0.12.0-esp32-20250422 (2025-04-22-13:02)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
DEPRECATED! use 'gdb port', not 'gdb_port'
DEPRECATED! use 'tcl port' not 'tcl_port'
DEPRECATED! use 'telnet port', not 'telnet_port'
CDRTOSConfigure
Info : only one transport option; autoselecting 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Info : Listening on port 50008 for tcl connections
Info : Listening on port 50009 for telnet connections
Info : esp_usb_jtag: serial (B0:81:84:96:9B:38)
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Error: libusb_bulk_write error: LIBUSB_ERROR_NOT_FOUND
/Users/lily/Library/Arduino15/packages/m5stack/tools/openocd-esp32/v0.12.0-esp32-20250422-cn/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
File "/Users/lily/Library/Arduino15/packages/m5stack/tools/openocd-esp32/v0.12.0-esp32-20250422-cn/bin/../share/openocd/scripts/target/esp_common.cfg", line 9, in script
File "/Users/lily/Library/Arduino15/packages/m5stack/tools/openocd-esp32/v0.12.0-esp32-20250422-cn/bin/../share/openocd/scripts/target/esp_common.cfg", line 9, in script -
@wingirl517
具体是哪一个示例? -
@wingirl517
看你这个问题压根不是编译的问题,你是不是在Arduino IDE里选了debug?你应该按左边那两个按钮的
