    i2c driver install error
    15 Posts 9 Posters 16.2k Views 4 Watching
    • kurikoK Offline
      kuriko @kmk68
      @kmk68
      Are you able to show your code?
      K 1 Reply Last reply Reply Quote 1
        kmk68 @kuriko
        @kuriko it's created by block editing...
        import os, sys, io
        import M5
        from M5 import *
        from label_plus import LabelPlus
        from hardware import *
        import time
        from unit import EncoderUnit
        label0 = None
        label1 = None
        label2 = None
        label3 = None
        BtnA = None
        BtnB = None
        BtnC = None
        rect0 = None
        rect1 = None
        rect2 = None
        rect3 = None
        rect4 = None
        rect5 = None
        rect6 = None
        rect7 = None
        rect8 = None
        rect9 = None
        rect10 = None
        rect11 = None
        rect12 = None
        rect13 = None
        rect14 = None
        rect15 = None
        rect16 = None
        rect17 = None
        rect18 = None
        rect19 = None
        label7 = None
        label8 = None
        label9 = None
        label10 = None
        label11 = None
        label12 = None
        label13 = None
        LA_4 = None
        LA_3 = None
        LA_2 = None
        LA_1 = None
        LB_4 = None
        LB_3 = None
        LB_2 = None
        LB_1 = None
        LC_4 = None
        LC_3 = None
        LC_2 = None
        LC_1 = None
        pin3 = None
        pin1 = None
        pin2 = None
        pin5 = None
        i2c1 = None
        pin25 = None
        pin26 = None
        pin35 = None
        pin36 = None
        encoder_0 = None
        l_enc_inc = None
        INT_clock = None
        t_values = None
        enc_mode = None
        curr_value = None
        loc_value = None
        Describe this function...
        def init_all_out_pins_as_():
        global l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value, label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0
        pin3 = Pin(3, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin1 = Pin(1, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin2 = Pin(2, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin5 = Pin(5, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin25 = Pin(25, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin26 = Pin(26, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin35 = Pin(35, mode=Pin.OUT, pull=Pin.PULL_UP)
        pin36 = Pin(36, mode=Pin.OUT, pull=Pin.PULL_UP)
        def relay_outs_pin_set():
        if t_values[-1] == INT_clock:
        pin3.value(1)
        if t_values[0] == INT_clock:
        pin1.value(1)
        if t_values[1] == INT_clock:
        pin2.value(1)
        if t_values[2] == INT_clock:
        pin5.value(1)
        if t_values[3] == INT_clock:
        pin25.value(1)
        if t_values[4] == INT_clock:
        pin26.value(1)
        if t_values[5] == INT_clock:
        pin35.value(1)
        if t_values[6] == INT_clock:
        pin36.value(1)
        if t_values[7] == INT_clock:
        pin25.value(0)
        if t_values[8] == INT_clock:
        pin26.value(0)
        if t_values[9] == INT_clock:
        pin35.value(0)
        if t_values[10] == INT_clock:
        pin36.value(0)
        if t_values[7] + 25 == INT_clock:
        pin3.value(0)
        if t_values[8] + 25 == INT_clock:
        pin1.value(0)
        if t_values[9] + 25 == INT_clock:
        pin2.value(0)
        if t_values[10] + 25 == INT_clock:
        pin5.value(0)
        def all_out_pins_to_zero():
        pin3.value(0)
        pin1.value(0)
        pin2.value(0)
        pin5.value(0)
        pin25.value(0)
        pin26.value(0)
        pin35.value(0)
        pin36.value(0)
        def setup():
        global label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0, l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value
        M5.begin()
        Widgets.fillScreen(0x222222)
        label0 = Widgets.Label("Key 1", 4, 185, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label1 = Widgets.Label("Key 1", 4, 135, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label2 = Widgets.Label("Key 2", 5, 85, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label3 = Widgets.Label("Key 4", 5, 35, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        BtnA = Widgets.Label("A", 60, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        BtnB = Widgets.Label("B", 150, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        BtnC = Widgets.Label("C", 240, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        rect0 = Widgets.Rectangle(100, 40, 40, 25, 0xffffff, 0x0f0957)
        rect1 = Widgets.Rectangle(143, 40, 40, 25, 0xffffff, 0x0f0957)
        rect2 = Widgets.Rectangle(186, 40, 40, 25, 0xffffff, 0x0f0957)
        rect3 = Widgets.Rectangle(229, 40, 40, 25, 0xffffff, 0x0f0957)
        rect4 = Widgets.Rectangle(100, 68, 40, 25, 0xffffff, 0x0f0957)
        rect5 = Widgets.Rectangle(143, 68, 40, 25, 0xffffff, 0x0f0957)
        rect6 = Widgets.Rectangle(186, 68, 40, 25, 0xffffff, 0x0f0957)
        rect7 = Widgets.Rectangle(229, 68, 40, 25, 0xffffff, 0x0f0957)
        rect8 = Widgets.Rectangle(100, 96, 40, 25, 0xffffff, 0x0f0957)
        rect9 = Widgets.Rectangle(100, 124, 40, 25, 0xffffff, 0x0f0957)
        rect10 = Widgets.Rectangle(100, 152, 40, 25, 0xffffff, 0x0f0957)
        rect11 = Widgets.Rectangle(143, 96, 40, 25, 0xffffff, 0x0f0957)
        rect12 = Widgets.Rectangle(186, 96, 40, 25, 0xffffff, 0x0f0957)
        rect13 = Widgets.Rectangle(229, 96, 40, 25, 0xffffff, 0x0f0957)
        rect14 = Widgets.Rectangle(143, 124, 40, 25, 0xffffff, 0x0f0957)
        rect15 = Widgets.Rectangle(186, 124, 40, 25, 0xffffff, 0x0f0957)
        rect16 = Widgets.Rectangle(229, 124, 40, 25, 0xffffff, 0x0f0957)
        rect17 = Widgets.Rectangle(143, 152, 40, 25, 0xffffff, 0x0f0957)
        rect18 = Widgets.Rectangle(186, 152, 40, 25, 0xffffff, 0x0f0957)
        rect19 = Widgets.Rectangle(229, 152, 40, 25, 0xffffff, 0x0f0957)
        label7 = Widgets.Label("A", 159, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label8 = Widgets.Label("B", 202, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label9 = Widgets.Label("C", 243, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label10 = Widgets.Label("K4", 112, 74, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label11 = Widgets.Label("K3", 113, 102, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label12 = Widgets.Label("K2", 113, 129, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        label13 = Widgets.Label("K1", 113, 157, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
        LA_4 = LabelPlus("0,0", 153, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LA_3 = LabelPlus("0,0", 153, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LA_2 = LabelPlus("0,0", 153, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LA_1 = LabelPlus("0,0", 153, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LB_4 = LabelPlus("0,0", 195, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LB_3 = LabelPlus("0,0", 195, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LB_2 = LabelPlus("0,0", 195, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LB_1 = LabelPlus("0,0", 195, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LC_4 = LabelPlus("0,0", 239, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LC_3 = LabelPlus("0,0", 239, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LC_2 = LabelPlus("0,0", 239, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        LC_1 = LabelPlus("0,0", 239, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
        i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
        t_values = bytearray(12)
        enc_mode = 0
        curr_value = 0
        INT_clock = 0
        encoder_0 = EncoderUnit(i2c1, 0x40)
        def loop():
        M5.update()
        time.sleep_us(20)
        if INT_clock == 0:
        time.sleep_ms(99)
        INT_clock = INT_clock + 1
        l_enc_inc = encoder_0.get_rotary_increments()
        if encoder_0.get_button_status():
        encoder_0.fill_color(0x990000)
        enc_mode = 1
        if l_enc_inc != 0:
        curr_value = curr_value + l_enc_inc
        while curr_value < 0:
        curr_value = curr_value + 12
        while curr_value > 11:
        curr_value = curr_value - 12
        else:
        encoder_0.fill_color(0x000066)
        enc_mode = 0
        if l_enc_inc != 0:
        loc_value = t_values[int(curr_value - 1)] + l_enc_inc
        if loc_value < 0:
        loc_value = 0
        if loc_value > 99:
        loc_value = 99
        t_values[int(curr_value - 1)] = loc_value
        if curr_value==0:
        LA_4.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==1:
        LA_3.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==2:
        LA_2.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==3:
        LA_1.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==4:
        LB_4.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==5:
        LB_3.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==6:
        LB_2.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==7:
        LB_1.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==8:
        LC_4.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==9:
        LC_3.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==10:
        LC_2.setText(str(((str((loc_value / 10))).strip())))
        elif curr_value==11:
        LC_1.setText(str(((str((loc_value / 10))).strip())))
        else:
        pass
        if name == 'main':
        try:
        setup()
        while True:
        loop()
        try:
        print_error_msg(e)
        except ImportError:
        • kurikoK Offline
          kuriko @kmk68
          @kmk68
          Can you export .m5f2 file on UiFlow2?
            Calvorotas
            I have problems with UiFlow 2.2.0.
            I could use BLE with UiFlow 2.1.8, but the same program doesn't run in 2.2.0.
            The progam can't start. The device return at Uiflow main menu.
            I have update UiFlow in the devices (Core M5stack and StickC, but I have the same problem.
            Thanks.
            C kurikoK 2 Replies Last reply Reply Quote 0
              Calvorotas @Calvorotas
              @Calvorotas
              Another program without BLE.
              I am not using MQTT in this program.
              Thanks.
              • kurikoK Offline
                kuriko @Calvorotas
                @Calvorotas
                can you provide the .m5f2 file? imma do a test to check out if it's a firmware problem
                nmstackN C 2 Replies Last reply Reply Quote 0
                • _ Offline
                  _e3e6
                  Same issue here with Atom Echo and the Web UIFlow 2.0
                  https://gist.github.com/e3e6/f8558f8487dad2fe8909c8dc17b80888
                  • nmstackN Offline
                    nmstack @kuriko
                    @kuriko
                    There is a few days ago, I wrote a similar trouble. My message was…
                    I didn't think that I could feel so interested about this system! Sorry for my questions about, because I'm very unexpert.
                    I'm math teacher in secondary in Spain, and I want to prepare a trigonometric practice very simple.
                    I've used a potenciometer (angle unit), PaHUB, PbHUB, 8servos unit, and two servos: one 360º limited, and another one, 360º unlimited. Until this moment, all was right. But, I've done some little changes, I wasn't conscient that, when I erased the PaHUB unit, and I added another one, some address changed. I reviewed all the program, and I think that it should run. But, I don't know why now, when my program is running, at the end of compilation, it appears this message "E (112496) i2c: i2c driver install error".
                    Thank you for your attention
                    Please, does someone aid me?
                    Thank you for my poor English. Best regards!
                    Neus
                    Neus Morlà
                      Calvorotas @kuriko
                      @kuriko
                      This is the file.
                      1 Reply Last reply Reply Quote 4
                        Hulkco @kuriko
                        @kuriko Several months have passed since this post, but the error persists. Do you really plan to fix it?!
                        M 1 Reply Last reply Reply Quote 2
                          mearsuit @Hulkco
                          yep...Same problem, i cant upload any python code without getting this error. Its a shame because its a really neat dev board and i really wish the people at m5stack would fix this problem. They would begin to see more projects being posted on the m5burner and it would only help their sales. Screenshot_2025-09-25_18-21-33.png
                          robskiR 1 Reply Last reply Reply Quote 1
                          • robskiR Offline
                            robski @mearsuit
                            @mearsuit i see this error from some time but projects are working ok
