    Error building latest m5dial code on vscode
    3 Posts 3 Posters 1.9k Views
    • G Offline
      gscorrea
      While trying to upload the m5dial fw into my m5dial I get the following error. What am I missing here? How can I fix this in order to continue the upload?
      'Compiling .pio\build\m5dial\lib285\LittleFS\LittleFS.cpp.o
      .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/platforms/esp32/Panel_EPD.cpp: In static member function 'static void lgfx::v1::Panel_EPD::task_update(lgfx::v1::Panel_EPD*)':
      .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/platforms/esp32/Panel_EPD.cpp:1003:27: error: no match for 'operator!=' (operand types are 'const lgfx::v1::Panel_EPD::update_data_t' and 'lgfx::v1::Panel_EPD::update_data_t')
      if (prev_data != new_data) { break; }
      In file included from .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/panel/../Panel.hpp:24,
      from .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/panel/Panel_Device.hpp:20,
      from .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/panel/Panel_HasBuffer.hpp:20,
      from .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/platforms/esp32/Panel_EPD.hpp:28,
      from .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/platforms/esp32/Panel_EPD.cpp:19:
      .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/panel/../misc/colortype.hpp:700:20: note: candidate: 'bool lgfx::v1::operator!=(const lgfx::v1::raw_color_t&, const lgfx::v1::raw_color_t&)'
      LGFX_INLINE bool operator!=(const raw_color_t& lhs, const raw_color_t& rhs) { return reinterpret_cast<const uint32_t>(&lhs) != reinterpret_cast<const uint32_t>(&rhs); }
      .pio/libdeps/m5dial/M5GFX/src/lgfx/v1/panel/../misc/colortype.hpp:700:20: note: no known conversion for argument 1 from 'const lgfx::v1::Panel_EPD::update_data_t' to 'const lgfx::v1::raw_color_t&'
      Compiling .pio\build\m5dial\FrameworkArduino\Esp.cpp.o
      *** [.pio\build\m5dial\lib145\M5GFX\lgfx\v1\platforms\esp32\Panel_EPD.cpp.o] Error 1
      ====================================================================================== [FAILED] Took 12.79 seconds ======================================================================================
      Environment Status Duration
      m5dial FAILED 00:00:12.788
      ===================== 1 failed, 0 succeeded in 00:00:12.788 =================================================================================
      • The terminal process "C:\Users\gscorrea.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'm5dial'" terminated with exit code: 1.
      • Terminal will be reused by tasks, press any key to close it.'
      • henryCharmH Offline
        henryCharm
        The error is happening because the code is trying to compare two update_data_t objects, but there's no defined way to compare them (no operator!=).
        To fix it, you need to either:
        Define a comparison function (operator!=) for update_data_t so it knows how to compare the two objects.
        Or, manually compare the relevant fields of prev_data and new_data.
        From a Data Science Intern to now happy as a IoT Solutions Architect.
          felmue @henryCharm
          Hello @gscorrea
          using the latest library versions, e.g. M5GFX 0.2.13 and M5Unified 0.2.8 I can build M5Dial firmware with no error.
