    MQTT subscribe and MQTT applying messaging on UIflow 2 and AomS3
    7 Posts 4 Posters 3.8k Views
    • B Offline
      bluedude
      I can publish but subscribe does not work. Any samples for UIflow 2?
      Also wondering what the MQTT apply messaging does.
      I really like M5stack hardware but the UIflow software is so so.
        felmue @bluedude
        Hello @bluedude
        I have an UIFlow2 example for M5Dial - which should give you some ideas.
        You can find it in the UIFlow Project Zone: M5Dial_WiFi_MQTT_UIFlow2.0.1
        • B Offline
          bluedude @felmue
          @felmue Hi, thanks!
          Checked the code and it's not different from mine. My MQTT server works for sure (tested it) but the subscribe event does not kick in.
          Need to investigate a few things.
          Do you also have a Smart Config WIFI sample maybe? That worked in UIFlow 1 but not in UI Flow 2.
          I want to be able to simply switch the WIFI settings when moving to other locations.
          felmueF M 3 Replies Last reply Reply Quote 0
            felmue @bluedude
            Hello @bluedude
            I just double-checked with M5AtomS3 and it works for me as well. UIFlow Project Zone: M5AtomS3_WiFi_MQTT_UIFlow2.1.5
            I am sorry, no, I do not have a Smart Config WiFi example.
              Mohir @bluedude
              @bluedude Hello,
                Mohir @bluedude
                @bluedude Hello, I have the same problem, I manage to publish but can't subscribe. Did you manage to solve the problem?
                • robskiR Offline
                  robski @Mohir
                  @Mohir see this link
