    Newbie failing on the first clock + battery with PaperS3
    2 Posts 2 Posters 688 Views
    • L Offline
      literakl
      I bought PaperS3 to build a dashboard displaying current time, weather forecast and bus departures. So far, I am unable to build a skeleton even after three weeks. My intention is to display the current time and a battery level and take a sleep for one minute. When running on a battery, I use deep sleep, because I target charging once per month. If connected to USB, I use a standard sleep to keep the USB connection (deep sleep kills it). Can you review my latest code please?
      import M5
      from M5 import *
      import time, machine
      SLEEP_MS = 60_000
      WIDTH = 540
      def get_battery():
          try:
              return Power.getBatteryLevel()
          except:
              return None
      def is_charging():
          try:
              return Power.isCharging()
          except:
              return False
      def draw_screen():
          Widgets.setRotation(2)
          Widgets.fillScreen(0xFFFFFF)
          t = time.localtime()
          day = t[2]
          month = t[1]
          year = t[0]
          h = t[3]
          m = t[4]
          batt = get_battery()
          batt_str = f"{batt}%" if batt is not None else "--%"
          date_str = f"{day}.{month}.{year}"
          time_str = f"{h:02d}:{m:02d}"
          battery_str = f"Battery: {batt_str}"
          FONT = Widgets.FONTS.DejaVu56
          y_start = 250
          spacing = 120
          Widgets.Label(date_str, WIDTH//2 - 100, y_start, 1.0,
                        0x000000, 0xFFFFFF, FONT)
          Widgets.Label(time_str, WIDTH//2 - 75, y_start + spacing, 1.0,
          Widgets.Label(battery_str, WIDTH//2 - 175, y_start + spacing * 2, 1.0,
          M5.update()
      def main():
          M5.begin()
          if is_charging():
              while True:
                  draw_screen()
                  time.sleep(2)
                  try:
                      machine.lightsleep(SLEEP_MS)
                  except:
                      time.sleep_ms(SLEEP_MS)
          else:
              draw_screen()
              time.sleep(2)
              try:
                  machine.deepsleep(SLEEP_MS)
              except:
      if __name__ == "__main__":
          main()
      So far I used AI tools to build the code. Thank you
      • robskiR Offline
        robski @literakl
        @literakl so are you able to display current time and battery level at all...forget about sleep option for now
