Python script runs successfully in Thonny but returns NameError: name 'Snowflake' isn't defined if run from app list
I created this simple app to play with animations
import M5 import random class Snowflake: def __init__(self): self.MAX_WIDTH = 320 self.MAX_HEIGHT = 240 self.radius = random.randint(2, 4) self.velocity = random.randint(2, 5) self.x = random.randint(0, self.MAX_WIDTH) self.y = random.randint(0, self.MAX_HEIGHT) def fall(self): self.y += self.velocity if self.y > self.MAX_HEIGHT: self._reset() def _reset(self): self.radius = random.randint(2, 4) self.velocity = random.randint(2, 5) self.x = random.randint(0, self.MAX_WIDTH) self.y = 2 def setup(): global SNOWFLAKES_COUNT global snow global circles SNOWFLAKES_COUNT = 80 snow=[] circles=[] M5.begin() M5.Widgets.fillScreen(0x66b8f7) for _ in range(SNOWFLAKES_COUNT): snow.append(Snowflake()) circles.append(M5.Widgets.Circle(0, 0, 0, 0xffffff, 0xffffff)) def loop(): M5.update() head = M5.Widgets.Circle(160, 144, 25, 0xffffff, 0xffffff) body = M5.Widgets.Circle(160, 199, 39, 0xffffff, 0xffffff) nose = M5.Widgets.Triangle(161, 143, 122, 150, 161, 148, 0xEA6511, 0xEA6511) left_eye = M5.Widgets.Circle(152, 135, 2, 0x000000, 0x000000) right_eye = M5.Widgets.Circle(167, 135, 2, 0x000000, 0x000000) for index, s in enumerate(snow): s.fall() c = circles[index] c.setRadius(r=s.radius) c.setCursor(x=s.x, y=s.y) if __name__ == '__main__': try: setup() while True: loop() except (Exception, KeyboardInterrupt) as e: try: from utility import print_error_msg print_error_msg(e) except ImportError: print("please update to latest firmware")If i run this code from Thonny pressing the run button it works, but if i run it from the the app list, i get this error:
MPY: soft reboot _ __ _ _ _(_)/ _| | _____ __ | | | | | |_| |/ _ \ \ /\ / / | |_| | | _| | (_) \ V V / \__,_|_|_| |_|\___/ \_/\_/ 2.0.3 _click_event_handler _click_event_handler Traceback (most recent call last): File "apps/snowman.py", line 60, in <module> File "apps/snowman.py", line 40, in setup NameError: name 'Snowflake' isn't defined MicroPython v1.22.0-dirty on 2024-03-21; M5STACK Core2 with ESP32(SPIRAM) Type "help()" for more information.Anyone knows the cause of this error and how to resolve it?
@Genio Hi I hope you have resolved this issue! would you please share how you handle this error in the end?
