    Bug report: UIFlow 2.0 can't save projects for Nano C6
    5 Posts 3 Posters 2.4k Views 1 Watching
      Physalice
      Hi! i've been trying to program and save project for my recently bought NanoC6, and it seems to be work fine, but when i'm trying to save it to the cloud - all blocks disappears when i'm trying to get back to project on other day :"(
      But strangely i can see blocks on the preview...
      It was flashed with UiFLow official software to be seamlessly connected to web code designer
      Order date: Aug 20, 2025 , but arrival was later due to the company announced holidays
      Version of UIFlow: 2.3.7
      Steps to re-production: any code or blocks placed on the field is not saving, but on preview it shows
      Example code:
      i hope it could be helpful since it is in the rules of bug report posting
      import os, sys, io
      import M5
      from M5 import *
      import network
      from hardware import I2C
      from hardware import Pin
      from unit import MiniOLEDUnit
      import time
      wifi_status = None
      Hr = None
      Min = None
      Sec = None
      Hr_line = None
      Min_line = None
      Sec_line = None
      wlan = None
      i2c0 = None
      minioled_0 = None
      Hour = None
      Minute = None
      Second = None
      tuple0 = None
      def setup():
      global wifi_status, Hr, Min, Sec, Hr_line, Min_line, Sec_line, wlan, i2c0, minioled_0, Hour, Minute, Second, tuple0
      M5.begin()
      M5.Lcd.setBrightness(100)
      wlan = network.WLAN(network.STA_IF)
      i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
      minioled_0 = MiniOLEDUnit(i2c0, 0x3c)
      Widgets.fillScreen(0x000000, minioled_0)
      wifi_status = Widgets.Label("wifi", 13, 0, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Hr = Widgets.Label("HR", 0, 10, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Min = Widgets.Label("Min", 0, 20, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Sec = Widgets.Label("Sec", 0, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Hr_line = Widgets.Label("Hours", 21, 10, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Min_line = Widgets.Label("Minutes", 21, 20, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      Sec_line = Widgets.Label("Seconds", 21, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu9, minioled_0)
      time.timezone('GMT+3')
      wlan.connect('SSID_NAME', 'PASSWORD')
      tuple0 = time.localtime()
      Hour = tuple0[3]
      Minute = tuple0[4]
      Second = tuple0[5]
      def loop():
      M5.update()
      if wlan.isconnected():
      wifi_status.setText(str('Wifi OK'))
      if not (wlan.isconnected()):
      wifi_status.setText(str('Wifi NO'))
      Hour = tuple0[3]
      Minute = tuple0[4]
      Second = tuple0[5]
      Hr.setText(str(Hour))
      Min.setText(str(Minute))
      Sec.setText(str(Second))
      while not (BtnA.wasSingleClicked()):
      M5.Lcd.setBrightness(0)
      break
      while BtnA.wasClicked():
      time.sleep(5)
      break
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
        felmue @Physalice
        Hello @Physalice
        hmm, works for me. Make sure you are logged into your account before attempting to save your work into the cloud.
        I created a small test - you could try to see if that loads the blocks for you. You can find it in the Project Zone called: M5NanoC6_RGB_LED_Blink_Test_UIFlow2.3.7
          Physalice @felmue
          @felmue Hmm... i can see it and import as well. why then i can't do it with my own stuff - is still mystery for me...
          I've been logged in in my account for whole time, but every time i do something and wanted get back to it on the other day - whole space is blank.
          This exact issue does not occuring if i trying do the same stuff but with CardPuter v1.1. it just loads with zero problems
            felmue @Physalice
            Hello @Physalice
            this is strange indeed. Unfortunately I have no idea why this only happens when using M5NanoC6, sorry.
            • kurikoK Offline
              kuriko
              Hi @felmue @Physalice
              This issue seems to be related to any unit with a screen. Anyway, we have fixed it!
