    Bluetooth Serial for Tab5
    3 Posts 3 Posters 1.8k Views
      MortenComadan
      Dear Forum,
      I have a project that relies on Bluetooth serial for communicating with a OBD2 Car Scanner.
      And I would like to use the Tab5. I have one, so even if it might be overkill that's what I'm trying.
      However I cannot find an example on how to use Bluetooth with the Tab5.
      Most of the examples wont work because the Tab5 have a wireless coprocessor instead of the main processor being the wireless module.
      I have searched high and low, and tried ChatGPT and the chatbot here.
      The best I can find is to rewrite the ESP32-C6 firmware or make a wrapper class for the ESP32-C6.
      Morten, Denmark.
      • B Offline
        BR123456 @MortenComadan
        @MortenComadan Hi,
        If your OBD2 scanner can work with BLE protocols, you can take a look at the following look for some guidance:
        https://uiflow-micropython.readthedocs.io/en/latest/system/m5ble.html
        There are examples there and some basic info on the higher level functions to handle BLE.
        • easytargetE Offline
          easytarget
          Hi @MortenComadan ; you don't mention what your project is based on for code; Arduino/ESP-IDF/MicroPython/UFlow2 etc..
          For the tools where Expressif have got involved the support should be there already. The C6 co-processor gets a standard firmware (that talks via QSPI to the P4) and the P4 IDF libraries know how to use this.
          • What I'm unsure about is exactly which features are actually implemented in the ESP IDF; I want to use bluetooth audio sink features.. eventually.
          If (like me) you are into MicroPython then good news. V1.27.0 was released a couple of days ago and has official P4 support: https://github.com/micropython/micropython/releases/tag/v1.27.0
          UFlow2 is based on an older micropython version; I'm not sure how much of the P4 stuff they may have backported.
          I only got my Tab5 today, I'm going to be installing micropython 1.27 asap.
