Flow 2 Execute block
Hello I was wondering if flow 2 had "Execute block" and if not is there a timline or is this feature going to be added. I would like to be able to use both the block system and custom code.
A block to execute custom code?
I use the Execute code block under System in UIFlow2
I'm a relative newbie so excuse me if that's not what you meant
@felmue ,
I am running V2.3.8, and all I see under System is "Execute mpy code (e.g. import)" and "Execute mpy code". I tried putting the blockExecute mpy code [print("## HELLO ##")]in the loop, but it had no effect. In fact, it wasn't translated to python code in the code window.
Did inserting python code directly get dropped?
Michael Huster -
Hello @ProfHuster
hmm, works for me with M5Tab5 UIFlow2 v2.3.9. It also got translated into Python code window.
Felix -
Hello @felmue,
I only get
execute mpy code []as a block.
You can see I reloaded and got V2.3.9. I get the same whether I choose a Tab5 or an Atom Echo. Or M5GFX or M5UI for the Tab5.
Hello @ProfHuster
below is an example filled with
print("hello"):
Please also have a look at my example in the UIFlow2 Project Zone called: M5Tab5_ExecuteMpyCodeTest_UIFlow2.3.9
Felix -
Thanks, that worked. I think what happened is I clicked on the code window and did some editing, then went back to the blockly panel. It seemed when I did that, the blockly no longer updated the actual python code.
I will check out your examples,
Prof Huster
Hello @ProfHuster
yes, that is what I observed too. As long as edit mode in Python code window is enabled, changes on the blockly side get ignored. (I guess that's to prevent changes from being overwritten.)
