    Running Immich with AI-Powered Image Search on Raspberry Pi 5 + AXera NPU
    1 Posts 1 Posters 843 Views 1 Watching
    • Y Offline
      yuyun2000
      TL;DR: Got Immich running with CLIP-based semantic search on a Raspberry Pi 5 using the AXera AX8850 NPU. Chinese language search works surprisingly well thanks to the ViT-L-14-336-CN model. Setup took about 30 minutes once I figured out the ML server configuration.
      What is Immich?
      Immich is an open-source, self-hosted photo and video management platform. Think Google Photos, but you control the data. It supports automatic backup, intelligent search, and cross-device access.
      Why This Setup?
      I wanted to test AI-accelerated image search on edge hardware. The AXera AX8850 NPU on our M5Stack development board provides hardware acceleration for the CLIP models, making semantic search actually usable on a Pi.
      Hardware Setup
      • Raspberry Pi 5
      • M5Stack AX8850 AI Module (provides NPU acceleration)
      • Standard Pi power supply and storage
      Step-by-Step Deployment
      1. Download the Pre-built Package
      Grab the optimized Immich build from HuggingFace:
      git clone https://huggingface.co/AXERA-TECH/immich
      Note: You'll need git lfs installed. If you don't have it, install it first.
      What you get:
      m5stack@raspberrypi:~/rsp/immich $ ls -lh
      total 421M
      drwxrwxr-x 2 m5stack m5stack 4.0K Oct 10 09:12 asset
      -rw-rw-r-- 1 m5stack m5stack 421M Oct 10 09:20 ax-immich-server-aarch64.tar.gz
      -rw-rw-r-- 1 m5stack m5stack    0 Oct 10 09:12 config.json
      -rw-rw-r-- 1 m5stack m5stack 7.6K Oct 10 09:12 docker-deploy.zip
      -rw-rw-r-- 1 m5stack m5stack 104K Oct 10 09:12 immich_ml-1.129.0-py3-none-any.whl
      -rw-rw-r-- 1 m5stack m5stack 9.4K Oct 10 09:12 README.md
      -rw-rw-r-- 1 m5stack m5stack  177 Oct 10 09:12 requirements.txt
      2. Load the Docker Image
      cd immich
      docker load -i ax-immich-server-aarch64.tar.gz
      If Docker isn't installed, you'll need to set that up first.
      3. Configure the Environment
      unzip docker-deploy.zip
      cp example.env .env
      4. Start the Core Services
      docker compose -f docker-compose.yml -f docker-compose.override.yml up -d
      Success looks like this:
      [+] Running 3/3
       ✔ Container immich_postgres  Started                                      1.0s
       ✔ Container immich_redis     Started                                      0.9s
       ✔ Container immich_server    Started                                      0.9s
      5. Set Up the ML Service (The Interesting Part)
      The ML service handles the AI-powered image search. It runs separately to leverage the NPU.
      Create and activate a virtual environment:
      python -m venv mich
      source mich/bin/activate
      Install dependencies:
      pip install https://github.com/AXERA-TECH/pyaxengine/releases/download/0.1.3.rc2/axengine-0.1.3-py3-none-any.whl
      pip install -r requirements.txt
      pip install immich_ml-1.129.0-py3-none-any.whl
      Launch the ML server:
      python -m immich_ml
      You should see:
      [10/10/25 09:50:12] INFO     Listening at: http://[::]:3003 (8698)
      [INFO] Available providers:  ['AXCLRTExecutionProvider']
      [10/10/25 09:50:16] INFO     Application startup complete.
      The AXCLRTExecutionProvider confirms the NPU is being used.
      Web Interface Configuration
      Initial Setup
      1. Navigate to http://<your-pi-ip>:3003 (e.g., 192.168.20.27:3003)
      2. First visit requires admin account creation - credentials are stored locally
      <img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/images/immich1.png" width="95%" />
      Configure the ML Server
      This is critical - the web interface needs to know where your ML service is running.
      1. Go to Settings → Machine Learning
      2. Set the URL to your Pi's IP and port 3003: http://192.168.20.27:3003
      3. Choose your CLIP model based on language:
        • Chinese search: ViT-L-14-336-CN__axera
        • English search: ViT-L-14-336__axera
      <img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/images/immich4.png" width="95%" />
      First-Time Index
      Important: You need to manually trigger the initial indexing.
      1. Go to Administration → Jobs
      2. Find "SMART SEARCH"
      3. Click "Run Job" to process your uploaded images
      <img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/images/immich6.png" width="95%" />
      Testing Image Search
      Upload some photos, wait for indexing to complete, then try semantic searches:
      <img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/images/immich7.png" width="95%" />
      The search works conceptually - you can search for "sunset" or "dogs playing" and it'll find relevant images even if those exact words aren't in the filename.
      Technical Notes
      • The NPU acceleration makes CLIP inference fast enough for interactive search
      • Chinese language support is genuinely good with the CN model
      • The ML server runs independently, so you can restart it without affecting the main Immich service
      • Docker handles PostgreSQL and Redis automatically
      Why M5Stack in This Stack?
      The AX8850 NPU module provides the hardware acceleration that makes this practical on a Pi. Without it, running CLIP inference would be too slow for interactive use. We're working on more edge AI applications that leverage this acceleration - this Immich setup is a good real-world test case.
      Questions about the setup or the NPU integration? Happy to dig into specifics.
