    ESP32 and RS485
    2 Posts 2 Posters 648 Views
      alex9
      I'm trying to use the RS485 interface on the M5Stack StampPLC (ESP32-S3 based) to transmit a test signal
      Problem:
      GPIO 0 measures 0V with a multimeter (should be 3.3V idle for UART)
      No signal appears on the oscilloscope — only millivolt noise
      Serial Monitor shows nothing (USB-CDC may not be configured)
      Questions:
      -Is GPIO 0 the correct TX pin for RS485 on StampPLC, or does it have a different pinout?
      -What are the correct build_flags in platformio.ini to enable USB-CDC on the ESP32-S3 variant used in StampPLC?
      -Is there an official StampPLC Arduino/PlatformIO example for RS485 communication?
        felmue @alex9
        Hello @alex9
        it looks like yes, GPIO0 is TX pin for RS485. See pinmap here.
        The platformio.ini example can be found here.
        Running a quick search I did not find an RS485 example, sorry.
        Edit: Maybe try this RS485 library.
