    Using M5Stack GPS Module v2.1 (ATGM336H) with Raspberry Pi Pico — No UART Output
    4 Posts 3 Posters 939 Views
    • O Offline
      obolland
      Context
      I am trying to use the M5Stack GPS Module v2.1 (ATGM336H) as a standalone UART GPS device with a Raspberry Pi Pico (MicroPython), not with an M5Stack host device.
      Goal
      My goal is simply to read raw NMEA sentences over UART.
      I want to receive standard NMEA output (e.g. $GNGGA, $GNRMC) from the module on a Pico UART RX pin.
      Hardware Setup
      GPS Module: M5Stack GPS Module v2.1 (ATGM336H)
      Microcontroller: Raspberry Pi Pico (MicroPython)
      Connections:
      GPS Module Pin 28 (5V) → Pico VBUS
      GPS Module Pin 1 (GND) → Pico GND
      GPS Module TX pin (various tested) → Pico GP1 (UART RX)
      Software (Pico / MicroPython)
      from machine import UART, Pin
      import time
      uart = UART(0, baudrate=9600, tx=Pin(0), rx=Pin(1))
      print("Listening...")
      while True:
      data = uart.read()
      if data:
      print(repr(data))
      time.sleep(0.1)
      Also tested at 115200 baud.
      What I Have Verified
      5V is present at the module (measured with multimeter)
      Ground is correctly connected
      Pico UART is working (used successfully in another part of the project)
      SMA antenna is connected
      Tested both 9600 and 115200 baud
      Tested multiple DIP switch configurations (one switch ON at a time)
      Pins Tested for GNSS_TX (based on docs):
      Pin 13
      Pin 15
      Pin 22
      Pin 26
      Pin 2
      Observed Behavior
      At 9600 baud: I consistently receive a single byte: b'\xff'
      At 115200 baud: no data at all
      No readable NMEA sentences are ever received
      Understanding / Confusion
      From the documentation and schematic:
      GNSS_TX is routed via DIP switch to M-Bus pins marked GNSS_TX(SW)
      DIP switch labels reference host GPIO (e.g. G1, G3, G17, etc.), not M-Bus pin numbers
      It is unclear how DIP switch positions map directly to M-Bus physical pins for standalone use.
      Questions
      What is the exact DIP switch configuration required to expose GNSS_TX on a specific M-Bus pin (e.g. pin 13 or 15)?
      Which M-Bus pin should be used for GNSS_TX when using the module outside of the M5Stack ecosystem?
      What is the correct default baud rate for this module (9600 vs 115200)?
      Does the module require any initialisation or enable signal before UART output begins?
      Is there any known issue using this module standalone (without an M5 host)?
      Goal Clarification
      I am not trying to configure or parse GPS data yet — I only need to confirm that raw UART NMEA output is present.
      Any guidance on correct DIP switch configuration and TX pin mapping for standalone use would be greatly appreciated!
      • O Offline
        obolland @obolland
        Bumping this - surely someone knows which pin exposes GNSS_TX?
        Any help greatly appreciated!
          felmue @obolland
          Hello @obolland
          according to the schematic GNSS_TX becomes M5-RXD which is then available (depending on set dip switch) on GPIOs: 3, 13, 16, 34 or 35 which translates to pins 13, 22, 15, 26 or 2 on the M5 Stack bus.
          BTW: Since you are not stacking the module you can set all dip switches to 'on' at the same time (if you like).
          Note: I do not have the M5Stack GPS Module v2.1 so I cannot test this myself.
            Danieldsouza
            The ATGM336H module defaults to 9600 baud for NMEA output and works standalone without an M5 host or init signal; it just needs power, antenna, and a clear sky view.
            Per the pinout diagram, GNSS_TX routes to M-Bus pins 13, 15, 21, 23 (RX side, but TX signal), or 26 via DIP switches (labels like G3/G13/etc). You've tested the right pins; try setting all DIP switches ON simultaneously (safe standalone), connect to pin 13 at 9600 baud, and wait 1-23s for hot/cold start. b'\xff' might be noise if the antenna signal is weak.
            Example code tweak: Use uart.any() and uart.readline() for cleaner NMEA capture. Doc's schematic confirms no enable needed.
