    195 Posts 79 Posters 571.0k Views 13 Watching
    • Z Offline
      zhumingqi @zhumingqi
      I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
      • Z Offline
        zhumingqi
        Today, I updated the UIFlow to V2.3.4, and burned V2.3.4 firmware as well. Then I tested that image component again with M5GFX in UIFlow 2.3.4. But the issue still exists. After I switch two JPG pics with one image component for sometime, the memory will reduced continiously. Finally, the system will break out. And I try to use gc.collect() after every drawImage(), but it's not useful.
        Here is my design and python code:
        import os, sys, io, gc
        import M5
        from M5 import *
        ImageSwitchFlag = None
        def GcCollectAndPrint():
        global ImageSwitchFlag
        gc.collect()
        print(gc.mem_free())
        pass
        def btnA_wasClicked_event(state):
        if ImageSwitchFlag == 0:
        M5.Lcd.drawImage("/flash/res/img/RotaryBGBacklight.jpg", 0, 0)
        GcCollectAndPrint()
        ImageSwitchFlag = 1
        elif ImageSwitchFlag == 1:
        M5.Lcd.drawImage("/flash/res/img/RotaryBGBT.jpg", 0, 0)
        GcCollectAndPrint()
        ImageSwitchFlag = 0
        def setup():
        M5.begin()
        Widgets.fillScreen(0x000000)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
        ImageSwitchFlag = 0
        def loop():
        M5.update()
        if name == 'main':
        try:
        setup()
        while True:
        loop()
        try:
        print_error_msg(e)
        except ImportError:
        print("please update to latest firmware")******
          Schwibach
          I wrote in another thread about my Sync... 0% problem.
          I am pretty sure now that it is a bug. I does not matter which program I use. I can run them from UIFlow 2.0. But as soon as I download a program, I will get the Sync... 0%
          Also, if I burn firmware without selecting startup, it will not even connect to UIFlow 2.0.
          I would really appreciate any guidance you could give.
          • O Offline
            otosan-maker
            I have found a bug in MQTT software. When I subscrive to a topic, the python code creates the subscription at the beggining of the setup code, before it connects to wifi and mqtt.
            Here is the sample:
            def setup():
            global page0, label0, LTemp, label1, temperatura, slider0, button0, off, mqtt_client, wlan, rotary
            mqtt_client.subscribe('termostato/temperatura', mqtt_termostato_temperatura_event, qos=0)
            M5.begin()
            m5ui.init()
            page0 = m5ui.M5Page(bg_c=0xffffff)
            label0 = m5ui.M5Label("Umbral", x=30, y=81, text_c=0x85231b, bg_c=0x302c2c, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
            LTemp = m5ui.M5Label("Temperatura:", x=41, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
            label1 = m5ui.M5Label("19,0", x=152, y=81, text_c=0x85231b, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
            temperatura = m5ui.M5Label("00.00", x=141, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
            slider0 = m5ui.M5Slider(x=38, y=119, w=160, h=22, mode=lv.slider.MODE.NORMAL, min_value=190, max_value=290, value=210, bg_c=0x115e9f, color=0x2c90e4, parent=page0)
            button0 = m5ui.M5Button(text="Set", x=54, y=172, bg_c=0x2196f3, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
            off = m5ui.M5Button(text="OFF", x=124, y=171, bg_c=0xf36021, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
            off.add_event_cb(off_event_handler, lv.EVENT.ALL, None)
            slider0.add_event_cb(slider0_event_handler, lv.EVENT.ALL, None)
            button0.add_event_cb(button0_event_handler, lv.EVENT.ALL, None)
            page0.screen_load()
            wlan = network.WLAN(network.STA_IF)
            rotary = Rotary()
            wlan.connect('bencab', 'arrabal6')
            rotary.set_rotary_value(19)
            mqtt_client = MQTTClient('m5termostato', '192.168.1.34', port=1883, user='user', password='pass', keepalive=33149)
            label1.set_text(str((slider0.get_value()) / 10))
            • O Offline
              otosan-maker
                Amani4791
                Hi there,
                I updated firmware on my Tab5 and installed UiFlow 2.0 V 2.4.0.
                I hoped for fixed UI libs, LVGL (M5UI) is not working for me:
                If I use pictures for button graphics (<30kB) hiding/ showing them to get 2 state feedback is very, very slow!
                The same graphics work fine/ fluent with old M5GFX, so I assume there must be a bug?
                Also: it seems that Wifi is not working anymore with V2.4.0: cannot get http calls.
                (also normally on booting Tab5 shows UIFlow settings page, with V2.4.0 not anymore and if I download project it's not booting...
                Hopefully you can fix it soon, I hoped to get something running over Christmas holidays ;-)
                Thanks a lot,
                Kind regards from Switzerland!
                Stephan
                • G Offline
                  GuerillaPlanter
                  Thank you for the M5Stack devices and coding tools. This community forum has been a great help too. I have been successfully using UiFlow2 to create code for a Cardputer. But I think there is a bug in the UiFlow2 web UI and/or m5f2 file format.
                  THIS WORKS: I can save to the cloud, save the project to a local file, and reimport that file, when the script is like:
                  sTestString = None
                  def setup():
                    global sTestString
                    M5.begin()
                    sTestString = 'hello'
                  def loop():
                    global sTestString
                    M5.update()
                  THIS DOESN'T WORK: If I edit it and assign a particular more complex value to the string, I cannot save to the cloud, nor reimport a file saved locally:
                  sTestString = 'OL,1,RW7###jp0 55  j"#k#!7##ih###4up j`%##7#'
                  This string happens to be a line from a teletext page .tti file, which includes some display control codes. Here is a screenshot of the code which can't be saved to the cloud or reimported, in the UiFlow2 UI:
                  Decoding this string's value is:
                  \u004f\u004c\u002c\u0031\u002c\u001b\u0052\u007f\u001b\u0057\u0037\u0023\u0023\u0023\u006a\u0070\u0030\u0020\u0035\u0035\u0020\u0020\u006a\u0022\u0023\u006b\u0023\u0021\u0037\u0023\u0023\u0069\u0068\u0023\u0023\u0023\u0034\u0075\u0070\u0020\u006a\u0060\u0025\u0023\u0023\u0037\u0023
                  While the script cannot be saved to the cloud (there is no response), the project can be saved to a local file. In the .m5f2 project file, the relevant saved value is:
                  <field name=\"VAR\" id=\"usN/c#7FD;q`ieH|V~5K\">sTestString</field><value name=\"VALUE\"><block type=\"text\" id=\"ap8ErHQgaUZ`^d-W-%_I\"><field name=\"TEXT\">OL,1,\u001bR\u001bW7###jp0 55  j\"#k#!7##ih###4up j`%##7#</field></block></value>
                  This local file cannot then by imported again into UiFlow2, giving an "error opening file" message:
                  I believe the problem is related to some unicode characters rather than the " character.
                  • W Offline
                    wmoorefi @ajb2k3
                    I am unable to get BaseX module to work with UI Flow 2.x firmware. I can get it to work with UI Flow 1.x.
                      RBOUMAN58
                      I noticed today uiflow2 is 2.4.4 instead of the 2.4.3 as yesterday.Working with a PaperS3 e-paper, my programs crash on missing fonts
                      AttributeError: type object 'Fonts' has no attribute 'Montserrat24'
                      Also Montserrat18 is mentioned many times.
                      These fonts are the fonts used in the prompts/labels on the screeneditor in uiflow2?
                      Anybody has seen same symptoms, so something wrong with 2.4.4?
                        RBOUMAN58 @RBOUMAN58
                        @RBOUMAN58
                        Got the problem solved, burned the 2.4.4 firmware using M5Burner, problems gone... programs are working again
                        • O Offline
                          Otis68
                          My STAM PLS stopped working after updating from version 2.4.4 to version 2.4.5. I used M5Burner to revert the firmware back to 2.4.4. But the STAM LPC program didn't work. OSError 261
                          • O Offline
                            Otis68
                            Good afternoon from Russia. Sorry for my English. I'm writing through a translator. I have your LTE modem, the NB-IoT2. And it's been sitting idle for almost a year. I wanted to use the NB-IoT2 with a STAM PLC to control a relay. But YOU still don't have proper documentation. Or an example of how it works. Between the modem and the phone. Will the documentation ever be completed?
