    Stackchan unboxing and setup troubleshoot
    stackchantroubleshootsetup
    11 Posts 5 Posters 917 Views
      janstackchan
      Hi M5stack team,
      Just received my new companion yesterday. Was exciting things up with new accounts and having a dedicated android phone with StackChan World app installed.
      Set up and binding has not been smooth and there does not seem like a lot of documented self help on this topic.
      When the unit is powered up.
      The landing page/
      Welcome Let's get started.
      Servo test-servo test completed
      Qr code to install the StackChan World app- installed
      ID ******2D8 look for me in the app to start set up.
      Having installed, registered and logged into StackChan World app, I tapped the +add new StackChan
      All menu selection will just roll and
      "Put new StackChan into binding mode"
      If welcome screen is display tap "next"
      Otherwise go to "SETUP" and tap change WiFi.
      This has previously been added and it still goes back to the ID ******2D8.
      been through this cycle probably about 10 times with no progress.
      Please help.
      JanStackChan
      A O 2 Replies Last reply Reply Quote 0
        HRHRacing
        In my case, this symptom occurred when the SSID of the WiFi access point connected to StackChan and my smartphone were not the same.
        This was because StackChan was connected on 2.4GHz and my smartphone was connected on 5GHz.
        When I switched my smartphone to 2.4GHz, it connected.
          Aleximdh @janstackchan
          I recently received package with StackChan and encountered a similar issue. StackChan connected to the same Wi-Fi network as my phone through the settings in the Android app. However, the AI.Agent voice assistant won't connect. It doesn't provide any connection instructions (as shown in the YouTube video). It doesn't respond to its name or any commands. The firmware automatically updated and then was reinstalled using M5Burner.
          I've checked everything, but I can't configure the AI.Agent.
          Could it be faulty, or should I check something else?
          • robskiR Offline
            robski @Aleximdh
            @Aleximdh what are your app settings re: ai agent? It worked on mine straight away
              Aleximdh @robski
              @robski, The problem is that AI.Agent does not show the settings. The device itself is connected to the phone and to Wi-Fi. But the AI.Agent is silent. He doesn't respond to my voice in any way.
              • robskiR Offline
                robski @Aleximdh
                @Aleximdh so your Agent Settings like Assistant Name/Language/LLM Model/ Voice Setting are blank?
                  Aleximdh @robski
                  @robski , All settings are default. Only Wi-Fi from my router is used on Android, and the same applies to StackChan.
                  Assistant Name - StackChan
                  Language - English
                  LLM Model - Qwen3 235B
                  Voice Setting - Skye
                  O robskiR 2 Replies Last reply Reply Quote 0
                  • O Offline
                    OgaStack @janstackchan
                    @janstackchan turn the Bluetooth of your mobile device on, while on the SSID page. It will sync your StackChan to your mobile device and proceed to the next stages of the setup and after that, it'll pull the latest software update from M5Stack
                    • O Offline
                      OgaStack @robski
                      @robski does remains your StackChan away from the default name lead to any issues?
                      • O Offline
                        OgaStack @Aleximdh
                        @Aleximdh has anyone tried picking on other models besides Qwen and had success?
                        • robskiR Offline
                          robski @Aleximdh
                          @Aleximdh same settings on mine, have you tried it on diff wifi?
