    How to get grove pin input?
    13 Posts 2 Posters 28.2k Views 1 Watching
      ajb2k3 @rmarinchev
      @rmarinchev Thanks, it was hard to help without know what sensor you were using.
      connect the yellow wire (pin1) to pins 35 or 36 (AD) on the base of the core.
        rmarinchev
        Thank you, that worked. However the sensor values are completely through the rought and I cannot modify it with the resistor as described in the GSR documentation. I think its because of the digital to analog convertion or its just an incompatibility. Anyway, this is outside the scope of this forum. Thank you for your help.
        ajb2k3A 3 Replies Last reply Reply Quote 1
          ajb2k3 @rmarinchev
          @rmarinchev Glad I could help.
          If you fix the issue, please come back here and let us know!
            ajb2k3 @rmarinchev
            @rmarinchev said in How to get grove pin input?:
            Have you read this?
            https://community.seeedstudio.com/Arduino+and+Galvanic+Skin+Response+(GSR)+Sensor-p-306.html
              ajb2k3 @rmarinchev
              based on the code on the seedstudio site, this UIFlow code may work.
              alt text
              but this is guesswork as I dont have the sensor.
                rmarinchev
                Yes, I tried this a few weeks ago with another esp32 board. I tried it also with arduino uno and seeeduino v4.2 boards. They work fine, however the esp32 was also giving wrong readings. To be honest, I bought the m5stack because I saw it had groove port, but I am new to this and I didn't know it can only get digital readings. I tried dividing by 4 since the esp32 gets a reading of 0-4092 and the other boards give a value of 0-1023. However the esp32 is still wrong. I also tried changing the
                    analogReadResolution(10)
                    analogSetWidth(10)
                But still the esp32 was giving false readings and I couldn't calibrate it as shown in the tutorials for gsr sensor (by turning the resistance until I get a reading of 512 without using the sensor)
                  Can you post photos of your setup please?
                  I curious to how its connected.
                    rmarinchev
                    The setup with the m5stack and the esp32 is as you said, just connect to 35 or 36 and read the analog input.
                      rmarinchev
                      And the seeedino is pretty straight forward. Here I have also a bluetooth module, since the seeeduino values are accurate, so I am using it as part of my prototype. The GSR sensor has a groove connector that plugs straight in the seeeduino port.
                        Thanks for the photos and nice work there.
                        Glad its all working for you now.
