    Blynk on M5Stack via uiFlow and block-maker
    32 Posts 5 Posters 150.3k Views 3 Watching
    • world101W Offline
      world101
      By the way, I haven't found a way to import existing m5b files into block-maker.m5stack.com, so here are the ones I created. Feel free to play around with them and even create some new ones! The official Blynk colors are here: http://docs.blynk.cc/#blynk-main-operations-change-widget-properties
      Blynk Init:
      import BlynkLib
      BLYNK_AUTH = ${auth_token}
      blynk = BlynkLib.Blynk(BLYNK_AUTH)
      Blynk Run:
      blynk.run()
      Uptime:
      @blynk.VIRTUAL_READ(${pin})
      def v${pin}_read_handler():
          time_val = time.ticks_ms() // 1000
          blynk.virtual_write(${pin}, time_val)
          lcd.textClear(${x}, ${y}, '      ', lcd.${bg_color})
          lcd.print(time_val, ${x}, ${y}, lcd.${fg_color})
      Slider: (Note, this is slightly different than the tutorial above. I was experimenting with passing a variable into the block. Feel free to adjust it as needed)
      @blynk.VIRTUAL_WRITE(${pin})
      def v${pin}_write_handler(value):
          ${variable} = '{}'.format(value).strip("['']")
          lcd.print(${variable}, ${x}, ${y}, lcd.${fg_color}, transparent=True, fixedwidth=True)
      Push Notification:
          if value:
              blynk.notify(${text})
      I'm really interested in how to link blocks together, like the m5stack team did for the MQTT blocks. But I'll start a new thread on that soon.
        Can you pm me your real name as I would like to credit you in my book for all the hard work on M5Blynk
          kmo
          Very cool! Can't wait to try it out!
          • world101W Offline
            world101
            I just noticed the Blynk developers released a new version 0.2.0 of blynk-library-python on git hub. I seems to have some additional advanced features like
            • debug logging
            • custom server
            • changing heartbeat
            • connected/disconnected events
            • generic virtual pin events
            • BlynkTimer
            I have not tried this out yet, but plan to in the next week or so. In case you wanted to try the older version of the library, here is the commit:
            https://github.com/vshymanskyy/blynk-library-python/commit/4cbf641fade72a11e797436a8656ebf28f239801
              ajb2k3 @world101
              @world101 I managed to build a private server on Saturday but having auto startup issues.
              I’ve tried the guide but still have to manually start the server
              • world101W Offline
                world101 @ajb2k3
                @ajb2k3 said in Blynk on M5Stack via uiFlow and block-maker:
                What platform did you build the local server on (Linux, RPi, etc)?
                  ajb2k3 @world101
                  @world101 RPI 2B
                  • world101W Offline
                    world101 @ajb2k3
                    Try the following:
                    edit the crontab
                    pi@raspberrypi:~ $ crontab -e
                    no crontab for pi - using an empty one
                    Select an editor. To change later, run 'select-editor'.
                    1. /bin/ed
                    2. /bin/nano <---- easiest
                    3. /usr/bin/vim.tiny
                    Choose 1-3 [2]: 2
                    Go to the end of the file and add the following command. Do not forget to modify the path to match your installation directory.
                    @reboot java -jar /home/pi/server-0.23.0.jar -dataFolder /home/pi/Blynk &
                    Source: https://diyprojects.io/blynk-how-to-install-a-private-local-server-on-raspberry-pi-3-unlimited-energy-test-wemos-dht22/#.XGvrGqROmEc
                      That’s the one I followed and still not auto loading. Will have another go tonight
                        kmo
                        @world101 Got everything working using UiFlow V1.2!
                          akshaypatil
                          Hi! I'm a complete beginner learning to use stickC, I managed to figure out Blynk with Arduino, but now, I'd like to do it with uiflow.
                          Since I have the latest versions of both (blynk.py - 0.2.6 & uiflow - 1.4.5.1), I wanted to know if the procedure is still the same. Also, if there are other reference links/good material to learn about esp32 with python, then do share!
                          I'm an industrial design student trying to make a battery-powered heated lunchbox for my thesis, which I'd like to control with the phone and also show nice graphics using stickC.
                          Any help appreciated!
                          Thank you :)
                            akshaypatil @akshaypatil
                            @akshaypatil said in Blynk on M5Stack via uiFlow and block-maker:
                            Thank you :)
                            Alright!
                            I figured how to upload and run the BlynkLib 0.2.0 on uiflow - 1.4.5. :D
                            The device is successfully detected and shown running on the android app.
                            Now, I only need to figure how to control/toggle GPIO pins through uiflow with Blynk. :)
                            Any tips? :P
                            P.S.
                            The push notification is not working. Is this limited to M5Stack only? Or also possible on my device...
                            • world101W Offline
                              world101 @akshaypatil
                              @akshaypatil
                              I haven’t worked with Blynk in a while, so I can’t comment on gpio control. If you end up getting something working, please share it.
                              I’ll see if I can find time to test push notifications on the m5stickC.
                              A 2 Replies Last reply Reply Quote 0
                                akshaypatil @world101
                                  @world101 Sure will!
                                  I was thinking if it was possible to insert the received virtual value from Blynk button here (orange block), one could toggle the GPIO pin.
                                  P.S. The push notifications work perfectly! Didn't add the notification widget. (silly me!)
                                  Now I just need to figure out to toggle GPIO through virtual values from the button.
                                    akshaypatil
                                    Done! :D
                                    from m5ui import *
                                    from uiflow import *
                                    from easyIO import *
                                    setScreenColor(0x111111)
                                    circle0 = M5Circle(40, 40, 25, 0xffffff, 0xffffff)
                                    import BlynkLib
                                    BLYNK_AUTH = 'Your Authentication KEY '
                                    @blynk.VIRTUAL_WRITE(4) # Button Widget on V4
                                    def my_write_handler(value):
                                      toggleIO(26)
                                    while True:
                                      blynk.run()
                                      wait_ms(2)
                                      @akshaypatil
                                      Here are the blocks for uiflow,
                                      http://s000.tinyupload.com/index.php?file_id=08084396321658982238
                                      and don't forget to use it together with the one uploaded by @world101 (https://www.dropbox.com/s/xosetw0qzin722l/Blynk.m5b?dl=0)
                                      Cheers! :)
