    M5Stack Offline Mode UI
    11 Posts 6 Posters 34.0k Views 1 Watching
    • m5-docsM Offline
      m5-docs @yurikleb
      @yurikleb
      Hello, these are two great gui library for you.
      https://github.com/InfiniteYuan1/esp32-lvgl-gui
      https://github.com/InfiniteYuan1/esp32-ugfx-gui
      M5Stack documentation URL
      https://docs.m5stack.com
      yuriklebY 1 Reply Last reply Reply Quote 1
      • m5-docsM Offline
        m5-docs @yurikleb
        @yurikleb
        M5Flow is growing. It will be better for supporting off-line working environment. Please waiting.
          ajb2k3 @m5-docs
          @watson 在 M5Stack Offline Mode UI 中说:
          @yurikleb
          @watson will it get the ability to make modified camera firmware?
          or at least allow us to make custom device while retaining the cameras function.
          • m5-docsM Offline
            m5-docs @ajb2k3
            Hey
            What's you specifically mean? I'm also interesting in the camera module(M5Camera).
              kurthofman
              I'm also looking for a way to use flow.m5stack.com or io.m5stack.com without internet-access.
              It would be great if we could setup our own server to wich the module can connect.
              Regards
                ajb2k3 @m5-docs
                Hey
                Allow user the ability to add to the base code and extend it ie and interrnet enabled smart camera doorbell.
                With the idf and command line being the only way to program the camera, I cant do much hacking :(
                • L Offline
                  LastCaress
                  Yes, please bring offline mode! Thanks!
                  • yuriklebY Offline
                    yurikleb @m5-docs
                    @watson Tanks!
                    Sorry for the slow response,
                    I will have a look into InfinateYuan1 Repos.
                    It seems like in one of them he is using lvgl.
                    Have you seen this post from a few weeks ago:
                    https://blog.littlevgl.com/2019-02-20/micropython-bindings
                    Do you think it's possible to add LittlevGL Micropython Binding to your next firmware build?
                    It shouldn't be too hard according to this part of the article:
                    https://blog.littlevgl.com/2019-02-20/micropython-bindings#how-can-i-use-it
                    Thanks!
                      salty_good
                      Hello, If you use Windows or Linux OS,
                      Please try UIFlow-Desktop-IDE !
                      1. You can download it from below. (firmware version must be >= 1.2.0)
                        https://m5stack.com/download
                      2. Please switch to USB-mode on the M5Stack setup screen.
                      Have a enjoy programming with M5Stack!
                      • m5-docsM Offline
                        m5-docs @yurikleb
                        @yurikleb Thank you! I already heard of little lvgl. But May be a long time later about adding it.
