    M5 burner not working on Macos X
    40 Posts 8 Posters 190.9k Views 4 Watching
      Alpine-Lake @ajb2k3
      @ajb2k3 So if I am ever able to flash the firmware in the device a new API will be generated ?
        ajb2k3 @Alpine-Lake
        @alpine-lake Sorry I didn't finish the post before sending it as I was walking.
        The Key is actually an Individual identity used for the server to communicate with specific devices.
        From what I understand, when you access UIFlow the server queries a list of devices that has communicated with it. when the key you put into your session is read by the server it will send commands to the Devices matching.
        Sorry If i'm not clear on this bit.
        I am located in the UK.
          ajb2k3 @Alpine-Lake
          @alpine-lake said in M5 burner not working on Macos X:
          Yes
            Alpine-Lake @ajb2k3
            @ajb2k3 Ok thank you. You are using the UI Flow IDE ?
              ajb2k3 @Alpine-Lake
              @alpine-lake yes, its all i can understand at the moment
                Alpine-Lake @ajb2k3
                @ajb2k3 You are referring to accessing the UI Flow web based correct ? I'm getting frustrated by the fact that the folks at M5 Stack can't point me in the right direction based on the symptoms I gave them.
                Let me ask you this, normally everything can be done from the UI Flow interface right ? By that I mean that no other app or programs are needed to flash the firmware or the user's application ?
                  Alpine-Lake @ajb2k3
                  @ajb2k3 and it's working ? On a Mac ? You didn't have issues to make it run properly ?
                    ajb2k3 @Alpine-Lake
                    @alpine-lake new firmware not running on macosx but my java is way out of date.
                      ajb2k3 @Alpine-Lake
                      normally yes, but they had to rebuild the server and i think something broke.
                        ok, i'm missing the react.js needed for the page to run.
                          Alpine-Lake @ajb2k3
                          @ajb2k3 I am trying to flash the M5 Stack with the UI Flow IDE, not the web based one. This is taking a lot of time. Is there any possibility to contact M5 development directly ?
                            ajb2k3 @Alpine-Lake
                            I'm also having trouble, it looks like the updater program is not working properly due to java.
                            You can go direct to facebook page
                              ajb2k3 @liushasha
                              @liushasha said in M5 burner not working on Macos X:
                              Please go to the official website and download the newest M5Burner 0_1558336217186_Screen Shot 2019-05-20 at 3.09.30 PM.png and keep the app file inside the folder.
                              As alpine lake said, just show a blank white screen.
                              • L Offline
                                liushasha
                                @Alpine-Lake @ajb2k3 Try to open the app file inside the contents folder .0_1558441586326_Screen Shot 2019-05-21 at 3.48.46 PM.png 0_1558441590343_Screen Shot 2019-05-21 at 3.49.41 PM.png
                                ajb2k3A 2 Replies Last reply Reply Quote 0
                                  ajb2k3 @liushasha
                                  @liushasha I have been, the app shows just a blank white page and if I directly access the web page in the folder that shows up a blank 2 panel page. I think is something to do with java as web dev is not liking the JavaScript used for the ui interface.
                                    ajb2k3 @liushasha
                                    The issue is not UIFLOW desktop, the issue is M5Burner!
                                    • nekointheboxN Offline
                                      nekointhebox
                                      Same issue with the latest M5Burner
                                        ajb2k3 @nekointhebox
                                        @nekointhebox said in M5 burner not working on Macos X:
                                        What OS X and java version are you running?
                                        • ozbkO Offline
                                          ozbk
                                          @ajb2k3 @Alpine-Lake @nekointhebox Maybe you can try to run following command in your M5Burner root directory.
                                          sudo chmod -R 777 .
                                          • L Offline
                                            liushasha @ajb2k3
                                            @ajb2k3 Is there anybody could tell who has tried to open up the app file from contents? the pic just demonstrates you how to open up an app file inside contents. 0_1558490983648_Screen Shot 2019-05-22 at 10.05.42 AM.png 0_1558490986961_Screen Shot 2019-05-22 at 10.03.35 AM.png
