    M5 stick C wont turn on am i missing something?
    15 Posts 11 Posters 45.6k Views 2 Watching
      cncninja
      Hi everyone hope you can help if I'm missing somthing., I bought a M5 stack C.. and I can't seem to get it to turn on. I've plugged the usb-c cable into a known good USB source and I get no charge indicator lights nothing. I've left it plugged in for a few hr and still nothing. I hold the power button for varying times from quick press to 6s to 15s and nothing happens I've tried all button and combination. i think i just have a bad one unless there is a trick i don't know. I've also tried a dedicated USB C charger from my phone and still nothing.... no light life or smoke just dead.. did i get a bad one? and if so how to get it replaced i tried the contact page and when I submit it just errors out. Any help would be great i really wanted to try uiflow
        If contact is not working you can try through facebook, instagram and email.
        Try sales@m5stack.com.
        • I Offline
          iPodLux
          Hi
          It did happened to me few times on new Sticks, it looks like the issue sometimes is the testing runtime used before shipping.
          Try this:
          If it doesn’t turn on connect it to your computer,
          launch the uiflow firmware utility,
          you should see the serial port listed (the serial port chip is independent from power supply and should work),
          erase content,
          burn with fresh firmware
          Repeat if necessary and make sure battery is charged
            Apparently it is a common issue with the battery protection circuit (I have experienced this now!)
            https://docs.m5stack.com/#/en/core/m5stickc
            • lukasmaximusL Offline
              @cncninja sorry to hear your having issues with the stickC. As @iPodLux said, try reflashing it. First though if it doesn't show up in device manager on windows or system report on Mac then you probably have a dud and we should be able to replace it for you
                heybin
                if some firmware in stickc, please connect g0 to 3.3V, next insert usbC,it will work well
                  heybin
                  https://docs.m5stack.com/#/en/faq q9
                  • world101W Offline
                    world101 @heybin
                    @heybin said in M5 stick C wont turn on am i missing something?:
                    Though this does work, I'm curious to know if you are working on a real fix via a firmware update.
                      heybin
                      sorry, this is caused by the battery voltage being too low(not booting for a long time). there is no way to solve it through the program,
                        cncninja
                        So i have a dead on arivel M5stick C and my m5 fire does not support the usb modual i bought to add usable I/O.... not really loving this..
                          jpilarski
                          I just wanted to mention if you charge the m5stickc using a usb psu such as what you use to charge your phone it seems to charge the stickc battery and it turns on if you give it a few minutes. Not sure if this might be attributed to the usb output voltage on my computer not being stable but this always works for me. On the usb psu the voltage was 5.01v and on the laptop it was 5.22v so perhaps the overvoltage is an issue. I have 3 or 4 stickc devices and on a couple of them I always have to charge them first before they will boot.
                          • MDARM Offline
                            MDAR
                            Hi
                            Is there any news on this subject?
                            I've got 4 X M5stickC units, with 3 being "dead on arrival"
                            Plugging them into my laptop brings them to life, but only 1 stays on when the usb power is removed.
                            I loaded this example script to get the Battery & supply voltages
                            https://github.com/m5stack/M5StickC/blob/ce1af7500b9d2370983c778266e1ea941ac9f2d8/examples/Advanced/AXP192/PowerWake/PowerWake.ino
                            The good one shows about 4v from the battery and 4.99v on the usb power.
                            The other three show
                            Battery ~0.003v
                            I've tried the G0 to GND trick, but that didn't work.
                            I did go looking for a new firmware, as mentioned above, but the link is dead.
                            Any help would be most welcomed.
                            • N Offline
                              nicolas @MDAR
                              @mdar thanks for pointing to this script, I have the same issue : 0v on battery !
                              • ZontexZ Offline
                                Zontex
                                Hi @nicolas @MDAR if you guys still encounter this issue please contact me at roni@m5stack.com to resolve it, thank you!
                                • E Offline
                                  Efried @Zontex
                                  @zontex After a longer charging my M5stick works, but it is not possible to switch it into USB or WLAN mode, so I may upload code.
                                  • R ren072 referenced this topic on
