    MAJOR BUG ! Connect to device broke
    27 Posts 8 Posters 103.4k Views 2 Watching
      I have just run a test from my end and I'm able to connect and program an M5stick and M5Go .
      What firmware are you running @LastCaress and @se7enmilgram are you running on your devices?
      Are you guys running the offline version or the version on flow.m5stack.com as the online version needs firmware 1.2.2 installed on your Sticks and stacks.
        You need to reset your web browsers and delete all saved data and cookies connected to M5Stack.com and uiflow.m5stack.com.
        Also deactivate content and add blockers for the above two sites.
          se7enmilgram @ajb2k3
          @ajb2k3 I only first burned the device yesterday, so it's running 1.2.2. I have a core devkit v1.0, off of amazon.
          This morning, I woke up and gave it another shot without resetting the m5stack in a new tab on my browser, and it just worked. I'm guessing whatever is going on here is on the server side, only because I didn't do anything differently.
            ajb2k3 @se7enmilgram
            @se7enmilgram said in MAJOR BUG ! Connect to device broke:
            Its strange because last night it was working for me and first thing this morning it was working as I'm working on my book today.
              @ajb2k3 I'll keep an eye on it and report back if the issue comes up again. I wonder if this was something related to a new device registration.
                It could be but it pops up every so often. I've even had it.
                • m5-docsM Offline
                  m5-docs @lelehel
                  @lelehel What's the specific phenomenon?
                  @ajb2k3 Does your device work well?
                  M5Stack documentation URL
                  https://docs.m5stack.com
                    heybin
                    I am positioning this problem and it may take a while, because I don't know when this problem will reappear again. :D
                    • E Offline
                      edstar
                      I am currently having the same issue.
                      Tried everything recommended in this post and still happening on 2 of my units. Tried different firmwares, computers and browsers, disabled all ad blocking, cleared cookies and nothing helped. In my case it was actually working fine with http://flow.m5stack.com/beta/ with firmware 1.3.4 and then all of a sudden it wouldn't work. Seems like it is server side?
                        heybin
                        fixed
