Goplus dc motor driver
My blower fan uses what I think is jst ph series which has a 2mm pitch.
It seems like it's a fraction too large for the m5 stack though.
Surely someone on this forum knows the specifics?
@rob-biernat Normally the fans connections are using the 2.54mm JST PH spacing which would explain the issues.
Ok no probs. For now I have stuff going with a jumper wire hack but I can buy some proper jst cables tommorow.
Is the person who wrote the go plus firmware and sample code on this forum? I can understand most of the code but since the code is not documented and not included in the m5 stack arduino library I need some help understanding the messages that get sent out on the i2c bus and what they do.
@rob-biernat Looks like he is but he is not active.
@zhouyang can you help? -
Ok so I have the dc motor controller working but when will the sample code be cleaned up and documented. At the moment it's a bit rough with lots of magic numbers scattered through the code. Ideally a proper api
Any updates from the bloke who wrote the code?
Anything from the programmer?
Is this the code in question?
#include <Arduino.h> #include <M5Stack.h> #define IrPin 13 #define PLUS_ADDR 0x62 int32_t number = 0; uint8_t press = 0; void setup() { M5.begin(true, false, false); M5.Lcd.setTextFont(6); M5.Lcd.clear(BLACK); M5.Lcd.setTextColor(ORANGE, BLACK); Wire.begin(); ledcSetup(1, 38000, 10); ledcAttachPin(IrPin, 1); } void plus_encode() { Wire.requestFrom(PLUS_ADDR, 2); while(Wire.available()) { int8_t encode = Wire.read(); uint8_t press_n = Wire.read(); number += encode; if(press_n == 0xff) { press = 0; } else { press = 1; } } } void loop() { char data[20]; plus_encode(); ledcWrite(1, ledcRead(1) ? 0 : 512); sprintf(data, "%d %d ", number, press); M5.Lcd.setCursor(100, 100); M5.Lcd.print(data); vTaskDelay(200); }I have a feeling the engineer who wrote the code may no longer work at M5Stack but i'll make an enquiry.
Ok given the bloke who wrote the code has left can someone please at least document the i2c messages?
https://github.com/m5stack/GoPlus/blob/master/src/src.ino this is sourece code
