Memory related issue
I am using M5Stack-Core_esp32 . compiler arduino.
when i compile my program it is showing that "sketch uses 1460566 bytes (111%) of program storage maximum is 1310720.
I have used OTA code , BLE and uart. How can i increase program memory. It is suppose to be 2MB.
It is showing only 1.25MB. -
@remeshck Hi Remeshck,
Check the discussion at the link below... hope it helps.
http://forum.m5stack.com/topic/132/m5stack-ble-client-for-owon-b35t-multimeter/3
from http://desire.giesecke.tk/index.php/2018/01/30/change-partition-size/
inside ..esp32\tools\partitions add new file for e.g. bigapp.csv with content:
# Name, Type, SubType, Offset, Size, Flags nvs, data, nvs, 0x9000, 0x5000, otadata, data, ota, 0xe000, 0x2000, app0, app, ota_0, 0x10000, 0x1E0000, app1, app, ota_1, 0x1F0000,0x1E0000, eeprom, data, 0x99, 0x3F0000,0x1000, spiffs, data, spiffs, 0x3F1000,0xF000,and inside esp32\boards.txt add new(copy) board like:
############################################################## m5stack_bigapp.name=M5Stack_bigapp m5stack_bigapp.upload.tool=esptool m5stack_bigapp.upload.maximum_size=1966080 m5stack_bigapp.upload.maximum_data_size=294912 m5stack_bigapp.upload.wait_for_upload_port=true m5stack_bigapp.serial.disableDTR=true m5stack_bigapp.serial.disableRTS=true m5stack_bigapp.build.mcu=esp32 m5stack_bigapp.build.core=esp32 m5stack_bigapp.build.variant=esp32 m5stack_bigapp.build.board=M5Stack_bigapp m5stack_bigapp.build.f_cpu=240000000L m5stack_bigapp.build.flash_size=4MB m5stack_bigapp.build.flash_mode=dio m5stack_bigapp.build.boot=dio m5stack_bigapp.build.partitions=bigapp m5stack_bigapp.menu.FlashMode.qio=QIO m5stack_bigapp.menu.FlashMode.qio.build.flash_mode=dio m5stack_bigapp.menu.FlashMode.qio.build.boot=qio m5stack_bigapp.menu.FlashMode.dio=DIO m5stack_bigapp.menu.FlashMode.dio.build.flash_mode=dio m5stack_bigapp.menu.FlashMode.dio.build.boot=dio m5stack_bigapp.menu.FlashMode.qout=QOUT m5stack_bigapp.menu.FlashMode.qout.build.flash_mode=dout m5stack_bigapp.menu.FlashMode.qout.build.boot=qout m5stack_bigapp.menu.FlashMode.dout=DOUT m5stack_bigapp.menu.FlashMode.dout.build.flash_mode=dout m5stack_bigapp.menu.FlashMode.dout.build.boot=dout m5stack_bigapp.menu.FlashFreq.80=80MHz m5stack_bigapp.menu.FlashFreq.80.build.flash_freq=80m m5stack_bigapp.menu.FlashFreq.40=40MHz m5stack_bigapp.menu.FlashFreq.40.build.flash_freq=40m m5stack_bigapp.menu.UploadSpeed.921600=921600 m5stack_bigapp.menu.UploadSpeed.921600.upload.speed=921600 m5stack_bigapp.menu.UploadSpeed.115200=115200 m5stack_bigapp.menu.UploadSpeed.115200.upload.speed=115200 m5stack_bigapp.menu.UploadSpeed.256000.windows=256000 m5stack_bigapp.menu.UploadSpeed.256000.upload.speed=256000 m5stack_bigapp.menu.UploadSpeed.230400.windows.upload.speed=256000 m5stack_bigapp.menu.UploadSpeed.230400=230400 m5stack_bigapp.menu.UploadSpeed.230400.upload.speed=230400 m5stack_bigapp.menu.UploadSpeed.460800.linux=460800 m5stack_bigapp.menu.UploadSpeed.460800.macosx=460800 m5stack_bigapp.menu.UploadSpeed.460800.upload.speed=460800 m5stack_bigapp.menu.UploadSpeed.512000.windows=512000 m5stack_bigapp.menu.UploadSpeed.512000.upload.speed=512000 m5stack_bigapp.menu.DebugLevel.none=None m5stack_bigapp.menu.DebugLevel.none.build.code_debug=0 m5stack_bigapp.menu.DebugLevel.error=Error m5stack_bigapp.menu.DebugLevel.error.build.code_debug=1 m5stack_bigapp.menu.DebugLevel.warn=Warn m5stack_bigapp.menu.DebugLevel.warn.build.code_debug=2 m5stack_bigapp.menu.DebugLevel.info=Info m5stack_bigapp.menu.DebugLevel.info.build.code_debug=3 m5stack_bigapp.menu.DebugLevel.debug=Debug m5stack_bigapp.menu.DebugLevel.debug.build.code_debug=4 m5stack_bigapp.menu.DebugLevel.verbose=Verbose m5stack_bigapp.menu.DebugLevel.verbose.build.code_debug=5 ##############################################################then for your big apps you can select this board
@reaper7 Hi Reaper7,
thanks for adding that helpful example.
