    Lesson 13. FACES. NES Games
    Scheduled Pinned Locked Moved Lessons and Guides
    14 Posts 8 Posters 36.5k Views 2 Watching
      cepics
      Hi, how can I do that on osx?
      tnks
      • lukasmaximusL Offline
        Hi @cepics instead of using the espflashdownload tool you can use esptool from the mac terminal
        1. download the github repository https://github.com/m5stack/M5Stack-nesemu
        2. install esptool from the setup file in the github repository https://github.com/espressif/esptool or
          from command line with
          pip install esptool
        3. Navigate to the firmware folder from the nes emulator repository and execute the flash.sh file
          ./flash.sh
          [NOTE] the flash.sh file should be edited with the name of the rom you wish to upload and that rom
          file should be in the same folder as the flash.sh file
          macsbug @cepics
          How to NES Games on Mac.
          NES GAME with M5STACK:2018.05.07
          Creation date : 2018.05.07
          Creator : macsbug
          https://macsbug.wordpress.com/2018/05/07/nes-game-with-m5stack/
            cepics @lukasmaximus
            @lukasmaximus said in Lesson 13. FACES. NES Games:
            ./flash.sh
            after executing flash.sh M5Stack start rebooting continously .....
              Perhaps you ought to erase the flash first, follow this and see if it resolves the issue https://www.youtube.com/watch?v=YlzlFqkzhtI&t=37s
                mumiytrol
                Why do I have inverted colors in my game?
                  @mumiytrol perhaps the rom you used is not compatible with the emulator. Did you try using other roms and did you have the same result?
                    mumiytrol @lukasmaximus
                    @lukasmaximus I used different rom, but there was such a problem with everyone
                      That's strange, I never came across this bug. Where did you download the M5Stack Nes emu from? from our official repo and which device were you using? and also how are you flashing the device with the firmware?
                        trevorbryden
                        I also successfully followed all these steps and loaded multiple NES roms from different sources...and all of them have inverted colors.
                          duthienkt
                          I had problem about color too, I tried to read other LCD libraries to know why.
                          The easy way to solve the problem is adding invert color command to ili_init_cmds.
                          I hope it's code will be updated soon.
