    Purchased a m5StickV - Fixed in recent firmware update.
    25 Posts 4 Posters 93.8k Views 1 Watching
      ajb2k3 @Xeon
      @xeon said in Purchased a m5StickV:
      @fpsychotic
      Did yours get very hot while charging?
      Yes, mine does get hot
      BTW there is already a MK2 on its way.
        Thrasher
        Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
          FPSychotic @ajb2k3
          Not really and it last some time with battery.
          v2? the wifi one? if is not wifi, what is the difference and were you got?
            ajb2k3 @FPSychotic
            @fpsychotic I've got the MK1 as the MKII isn't out yet
            • X Offline
              Xeon
              i verified it.
              after reaching 70 to 90% full battery the device wont power off.
              it just reboots.
              after going below this threshold it turns off again normally.
              The war of 1 and 0 draws ever closer.
              everyday i work to become a cyborg.
                Thrasher
                Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
                • X Offline
                  Xeon
                  Well my battery is now rotten thanks to this.
                  The battery life is fading very fast.
                  I want a replacement.
                  i bought this device to get a task done.
                  it's going to.
                    ajb2k3 @Xeon
                    @xeon have you contacted M5Stack support about this? They should be available now
                    • X Offline
                      Xeon @ajb2k3
                      @ajb2k3 said in Purchased a m5StickV:
                      They verified the problem and will release a fix soon.
                        ajb2k3 @Xeon
                        Glad to hear it.
                        • X Offline
                          Xeon @ajb2k3
                          @ajb2k3 So far i managed to program a demo with all the source lying around thanks to our great friends here sharing.
                          But there are a few source examples i'm looking for.
                          i'm trying to make a program that tests as many functions and features as possible.
                          import audio
                          import gc
                          import image
                          import lcd
                          import sensor
                          import sys
                          import time
                          import utime
                          import uos
                          import _thread
                          import pmu
                          import KPU as kpu
                          from fpioa_manager import *
                          from machine import I2C
                          from Maix import I2S, GPIO
                          time.sleep(2)
                          Initialize
                          Lcd setup
                          lcd.init()
                          lcd.rotation(2)
                          i2c = I2C(I2C.I2C0, freq=400000, scl=28, sda=29)
                          Speaker setup
                          fm.register(board_info.SPK_SD, fm.fpioa.GPIO0)
                          spk_sd=GPIO(GPIO.GPIO0, GPIO.OUT)
                          spk_sd.value(1) #Enable the SPK output
                          fm.register(board_info.SPK_DIN,fm.fpioa.I2S0_OUT_D1)
                          fm.register(board_info.SPK_BCLK,fm.fpioa.I2S0_SCLK)
                          fm.register(board_info.SPK_LRCLK,fm.fpioa.I2S0_WS)
                          wav_dev = I2S(I2S.DEVICE_0)
                          Init battery monitor axp192
                          axp = pmu.axp192()
                          axp.enableADCs(True)
                          Setup A and B buttons
                          fm.register(board_info.BUTTON_A, fm.fpioa.GPIO1)
                          but_a=GPIO(GPIO.GPIO1, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                          fm.register(board_info.BUTTON_B, fm.fpioa.GPIO2)
                          but_b = GPIO(GPIO.GPIO2, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                          but_a_pressed = 0
                          but_b_pressed = 0
                          but_stu = 1
                          cnt_f = 0
                          Setup LED's
                          fm.register(board_info.LED_W, fm.fpioa.GPIO3)
                          led_w = GPIO(GPIO.GPIO3, GPIO.OUT) #RGBW "White" LED
                          led_w.value(1) #RGBW "White" LED is Active Low
                          fm.register(board_info.LED_R, fm.fpioa.GPIO4)
                          led_r = GPIO(GPIO.GPIO4, GPIO.OUT) #RGBW "Red" LED
                          led_r.value(1) #RGBW "Red" LED is Active Low
                          fm.register(board_info.LED_G, fm.fpioa.GPIO5)
                          led_g = GPIO(GPIO.GPIO5, GPIO.OUT) #RGBW "Green" LED
                          led_g.value(1) #RGBW "Green" LED is Active Low
                          fm.register(board_info.LED_B, fm.fpioa.GPIO6)
                          led_b = GPIO(GPIO.GPIO6, GPIO.OUT) #RGBW "Blue" LED
                          led_b.value(1) #RGBW #RGBW "Blue" LED is Active Low
                          Define image filters
                          origin = (0,0,0, 0,1,0, 0,0,0)
                          edge = (-1,-1,-1,-1,8,-1,-1,-1,-1)
                          sharp = (-1,-1,-1,-1,9,-1,-1,-1,-1)
                          relievo = (2,0,0,0,-1,0,0,0,-1)
                          Subs
                          def fade_scrn(fspd,dirr): # Use backlight to fade screen dirr = dirrection 0 = in 1 = out
                          for i in range(9):
                          if dirr == 0:
                          set_backlight(i)
                          if dirr == 1:
                          ti = 9 - i
                          set_backlight(ti)
                          time.sleep(fspd)
                          def play_sound(filename,vol):
                          try:
                          player = audio.Audio(path = filename)
                          player.volume(vol)
                          wav_info = player.play_process(wav_dev)
                          wav_dev.channel_config(wav_dev.CHANNEL_1, I2S.TRANSMITTER,resolution = I2S.RESOLUTION_16_BIT, align_mode = I2S.STANDARD_MODE)
                          wav_dev.set_sample_rate(wav_info[1])
                          while True:
                          ret = player.play()
                          if ret == None:
                          break
                          elif ret==0:
                          break
                          player.finish()
                          except:
                          pass
                          def set_backlight(level): # Set backlight brightness ranges from 0 to 8
                          if level > 8:
                          level = 8
                          if level < 0:
                          level = 0
                          val = (level+7) << 4
                          i2c.writeto_mem(0x34, 0x91,int(val))
                          def show_logo():
                          led_r.value(0)
                          img = image.Image("/sd/startup1.jpg")
                          time.sleep(0.15)
                          led_r.value(1)
                          set_backlight(0)
                          lcd.display(img)
                          fade_scrn(0.02,0)
                          led_w.value(0)
                          led_b.value(0)
                          play_sound("/sd/logo.wav",70)
                          led_b.value(1)
                          fade_scrn(0.02,1)
                          img = image.Image("/sd/startup2.jpg")
                          lcd.display(img)
                          fade_scrn(0.02,0)
                          play_sound("/sd/ding1.wav",70)
                          time.sleep(2)
                          led_w.value(1)
                          def init_camera(): #initialize sensor
                          led_b.value(0)
                          led_r.value(0)
                          err_counter = 0
                          while 1:
                          try:
                          sensor.reset() # Reset sensor.
                          break
                          except:
                          err_counter = err_counter + 1
                          if err_counter == 20:
                          led_r.value(0) # Led stays red if sensor failed to initialize.
                          lcd.draw_string(lcd.width()//2-100,lcd.height()//2-4, "Error: Sensor Init Failed", lcd.WHITE, lcd.RED)
                          time.sleep(0.1)
                          continue
                          led_b.value(1)
                          led_r.value(1)
                          led_g.value(0) # Led turns Green meaning all good.
                          play_sound("/sd/ding2.wav",70)
                          sensor.set_pixformat(sensor.RGB565)
                          sensor.set_framesize(sensor.QVGA) #QVGA=320x240
                          sensor.run(1)
                          time.sleep(0.5)
                          led_g.value(1)
                          def show_batt_stats():
                          val = axp.getVbatVoltage()
                          img.draw_string(52, 60, "Bat V:" + str(val), color=(230,0,0))
                          val = axp.getBatteryDischargeCurrent()
                          img.draw_string(52, 72, "Bat I:" + str(val), color=(230,0,0))
                          val = axp.getUSBVoltage()
                          img.draw_string(52, 84, "USB V:" + str(val), color=(230,0,0))
                          val = axp.getUSBInputCurrent()
                          img.draw_string(52, 96, "USB I:" + str(val), color=(230,0,0))
                          val = axp.getBatteryInstantWatts()
                          img.draw_string(52, 108, "I W:" + str(val), color=(230,0,0))
                          val = axp.getTemperature()
                          img.draw_string(52, 120, "Temp*:" + str(val), color=(230,0,0))
                          def apply_filter(cnt_f):
                          if cnt_f==1: #cycle filters 1=edge, 2=sharp, 3=relievo, 4=origin, 0 = skip filter
                          img.conv3(edge)
                          img.draw_string(52,60, "edge",color=(255,0,0))
                          elif cnt_f==2:
                          img.conv3(sharp)
                          img.draw_string(52,60, "sharp",color=(255,0,0))
                          elif cnt_f==3:
                          img.conv3(relievo)
                          img.draw_string(52,60, "relievo",color=(255,0,0))
                          elif cnt_f==4:
                          img.conv3(origin) #reset filter
                          img.draw_string(52,60, "origin",color=(255,0,0))
                          else :
                          cnt_f=0
                          Main
                          show_logo()
                          if but_a.value() == 0: #If dont want to run the demo
                          img = image.Image("/sd/startup3.jpg")
                          lcd.display(img)
                          print('[info]: Exit by user operation')
                          fade_scrn(0.02,1)
                          time.sleep(0.02)
                          set_backlight(0)
                          sys.exit()
                          init_camera()
                          Define list of classes
                          classes = ['aeroplane', 'bicycle', 'bird', 'boat', 'bottle', 'bus', 'car', 'cat', 'chair', 'cow', 'diningtable', 'dog', 'horse', 'motorbike', 'person', 'pottedplant', 'sheep', 'sofa', 'train', 'tvmonitor']
                          task = kpu.load("/sd/model/20class.kmodel")
                          task_face = kpu.load(0x300000) # default face detection model on flash memory
                          task_face = kpu.load("/sd/model/facedetect.kmodel") # you can extract the model from default .kfpkg
                          anchor = (1.889, 2.5245, 2.9465, 3.94056, 3.99987, 5.3658, 5.155437, 6.92275, 6.718375, 9.01025)
                          Anchor data is for bbox, extracted from the training sets.
                          kpu.init_yolo2(task, 0.5, 0.3, 5, anchor)
                          kpu.init_yolo2(task_face, 0.5, 0.3, 5, anchor)
                          print('[info]: Started.')
                          fade_scrn(0.02,1)
                          img = sensor.snapshot()
                          lcd.display(img)
                          fade_scrn(0.02,0)
                          led_g.value(1)
                          green_threshold = (0, 80, -70, -10, -0, 30)
                          try:
                          while(True):
                              img=sensor.snapshot() # Take Snapshot
                              # Press B and A to cycle thru filters
                              if but_b.value() == 0 and but_a.value() == 0 and but_b_pressed == 0:
                                  cnt_f=cnt_f+1
                                  but_b_pressed=1
                                  #play_sound("/sd/ding2.wav",70)
                              if but_b.value() == 1 and but_a.value() == 0 and but_b_pressed == 1:
                                  but_b_pressed=0
                              if cnt_f==5:
                                  cnt_f=0
                              apply_filter(cnt_f)
                              gc.collect()
                              code_obj = kpu.run_yolo2(task, img)
                              code_face = kpu.run_yolo2(task_face, img)
                              if code_obj: # object detected
                                  max_id = 0
                                  max_rect = 0
                                  for i in code_obj:
                                      img.draw_rectangle(i.rect())
                                      text = ' ' + classes[i.classid()] + ' (' + str(int(i.value()*100)) + '%) '
                                      for x in range(-1,2):
                                          for y in range(-1,2):
                                              img.draw_string(x+i.x(), y+i.y()+(i.h()>>1), text, color=(255,255,255), scale=1.5,mono_space=False)
                                      img.draw_string(i.x(), i.y()+(i.h()>>1), text, color=(255,25,25), scale=1.5,mono_space=False) #display detected object name
                                      id = i.classid()
                                      rect_size = i.w() * i.h()
                                      if rect_size > max_rect:
                                          max_rect = rect_size
                                          max_id = id
                                  if but_a.value() == 0 and but_b.value() == 1:
                                      led_w.value(0)
                                      play_sound("/sd/voice/en/"+str(max_id)+".wav",70)
                                      led_w.value(1)
                              if code_face: # face detected
                                  max_id = 0
                                  max_rect = 0
                                  for i in code_face:
                                      img.draw_rectangle(i.rect(),color=(230,0,0))
                              if but_b.value() == 0 and but_a.value() == 1: # press B for battery stats overlay
                                  show_batt_stats()
                              #gc.collect()
                              #blobs = img.find_blobs([green_threshold])
                              #if blobs:
                                  #for b in blobs:
                                      #tmp=img.draw_rectangle(b[0:4])
                                      #tmp=img.draw_cross(b[5], b[6])
                                      #c=img.get_pixel(b[5], b[6])
                              lcd.display(img)
                          except KeyboardInterrupt:
                          kpu.deinit(task)
                          kpu.deinit(task_face)
                          sys.exit()
                            Thrasher
                            Xeon, I've noticed pretty same problem on my stick-v today.
                            Whenever I press and hold turn-off button stick reboots instead of turning off.
                            In my case this happens whenever SD card is plugged in. I've removed it and everything works as intended now
                            • X Offline
                              Xeon @Thrasher
                              @thrasher
                              latest Firmware fixes this.
                              http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade
