    m5Stack basic. Wrong colors.
    5 Posts 3 Posters 10.8k Views 1 Watching
    • B Offline
      borisu
      Hi everybody. Please advise. I got two cores basic ones. I use Arduino IDE. If I load following code M5.Lcd.fillScreen(WHITE) I get black screen. I have similar issues with all of the other colors. I have this problem on both devices. There were no such issue on old core. Could someone suggest what to do in such case. Thanks.
      in addition I tested different hex codes of colors. Again 0x000000 gives me white screen and 0xeeeeee gives black. Is it possible to fix?
        staberas @borisu
        @borisu
        Please provide the code you upload
        • B Offline
          borisu
          The code is simple
          #include <M5Stack.h>
          // Lcd should display blue
          M5.Lcd.fillScreen(BLUE);
          void loop(){
          In this case the screen is something between yellow and green.
          • B Offline
            borisu
            It works if add
            #include<M5Stack.h>
            void setup(){
            M5.Lcd.invertDisplay(true)
            void loop(){
            • m5stackM Online
              hi , did your has upgrade your library version to latest. (m5stack lib version >= 0.2.8)
