    How to control lots of Neopixel
    30 Posts 6 Posters 109.9k Views 4 Watching
    • O Offline
      osc @ajb2k3
      Thank you for your reply and movie url!
      I understand supply additional power from port of usb-c.
      I would like to know your device between your made cable and mobile battery.
      And I will supply that from AC[single phase] 100V 15A. So should I need a AC-DC converter like above url?
      https://amzn.to/2Swk7s4
      • O Offline
        osc @Thrasher
        @thrasher
        Thank you for your reply~
        So I need more than 21A !!
        I wonder if M5Stack can do with huge amp...
          ajb2k3 @osc
          @osc you will need a slightly different cable to use the PSU and you would connect like this.
          alt text
            Thrasher
            You can actually power up arduino/m5stack from USB or any other source, just make sure all grounds are connected (black wire)
            • O Offline
              osc @ajb2k3
              Thank you for nice tips!
              I understand how PSU and then, I'm researching how connect multiple LED strips.
              I think I just need a hub for controlling each strips.
              Maybe like above unit?
              https://m5stack.com/products/pahub-unit?_pos=2&_sid=469853686&_ss=r
              • O Offline
                osc @Thrasher
                @thrasher
                I hope I can make it with supplying from USB Power like Apple USB adaptor!
                Could you tell me more detail about that?
                ajb2k3A T 2 Replies Last reply Reply Quote 0
                  ajb2k3 @osc
                  @osc all each strip needs is data and gnd from the M5Stack. My lead can be used on any USB adapter that can provide enough power. The power supply you linked to only needs the 5V and gnd connected to the strip but both the supply and the M5Stack must have the gnd connected together.
                  In addition if you have a pattered you want duplicated on a second strip you can connect strips together in parallel
                    Thrasher @osc
                    @osc Considering strip will drain >10 A current you can compare it with apple adaptor output. Strips usually come with power source unit which provide heavy load
                    • O Offline
                      osc @ajb2k3
                      Thank you for your kind explanation!
                      So I almost can't M5Stack's unit cable which I bought haha.
                      I just wonder which pins of M5Stack could I connect to?
                      I know M5Stack has only two DAC pins.
                      Could you tell me which good extension device??
                      thank you so much!
                      • O Offline
                        osc @Thrasher
                        @thrasher
                        Thank you for you good tips!
                        So I should two adaptor like below.
                        https://amzn.to/3bN7tfR
                        or this? That's too expensive..
                        https://www.sanwa.co.jp/product/syohin.asp?code=ACA-IP64
                          Thrasher
                          https://www.aliexpress.com/item/4000385799147.html?spm=a2g0o.productlist.0.0.398a3026DnIolq&algo_pvid=018f702f-143e-4ac7-b710-40149cfef11f&algo_expid=018f702f-143e-4ac7-b710-40149cfef11f-1&btsid=0b8b035c15819462182664106ee8a3&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                          16$ for 20A one
                          • O Offline
                            osc @Thrasher
                            @thrasher
                            Thank you for your fast reply!
                            I would check my schedule!~
                              ajb2k3 @osc
                              @osc Port A is ok for RGB LEDS, all you need to do is provide additional pins to the black and red wires.
                              Black, white and yellow remain connected between the M5Stack snd the leds
                              I need to make a picture :(
                              @Thrasher not all LED strips come with power supplies, Most RGB/neopixel/WS2812/SK6812 come without power supplies.
                              O 2 Replies Last reply Reply Quote 0
                              • O Offline
                                osc @ajb2k3
                                Thank you for your precise explanation!
                                So I can still use M5Stack's unit cable and PaHub!
                                I checked PaHub code above example here and tried to use UIflow.
                                https://docs.m5stack.com/#/en/unit/pahub
                                But I can't click the number and can't expect how programming..
                                Maybe I have to ask other question thread~
                                Thank you so much!
                                V14.3
                                alt text
                                • O Offline
                                  osc @ajb2k3
                                  ![alt text](0_1581964708701_Screen Shot 2020-02-18 at 3.33.03.png image url)
                                    ajb2k3 @osc
                                    @osc Looks like you have discovered a bug however you don't need the hub to control the LEDS
                                    Also you dont need the i2c block
                                    • O Offline
                                      osc @ajb2k3
                                      So how could I add more pin for controlling five strips each from portA??
                                        ajb2k3 @osc
                                        @osc Each strip has data in and data out. you connect data in of the first strip to the m5stack and then the data in of the next strip is connected to data out of the first.
                                        alt text
                                        alt text
                                          Thrasher
                                          Go hardcore. 74HC595
                                          • O Offline
                                            osc @ajb2k3
                                            Thank you for reply!
                                            I understand how to connect from one pin.
                                            Then I need to choose each cables between strips which has allowable current 4A, isn't it?
                                            @Thrasher
                                            At first I hoped I could use thin cables to each strips from each pins.
                                            I should research about 74HC595. Thanks!
