How to use Unicode.
Github Display_Unicode example has an error.
***CUF_24px.h:156463:7: error: 'EncodeRange' does not name a type
const EncodeRange CUF_24pxEncodeRange[] PROGMEM = {***
Pls modify <m5stack path>/src/utility/In_eSPI_Setup.h, At the end of the file add "#define USE_M5_FONT_CREATOR"
you could check the note in the code head
Add the In_eSPI_Setup.h file to the aduino IDE project, and #define.. Does this mean that the annotation should be lifted?
same error.
I have the same problem with "Display_Unicode" example. I added "#define USE_M5_FONT_CREATOR", but now I have the error: "Sketch to big"
Please, help me. I need Unicode characters. -
@tehnolog I solved my problem
Unicode characters can then be entered by holding down Alt , and typing + on the numeric keypad, followed by the hexadecimal code – using the numeric keypad for digits from 0 to 9 and letter keys for A to F – and then releasing Alt .
