    M5Stack 2 Channel Oscilloscope
    20 Posts 8 Posters 66.5k Views 3 Watching
    • reaper7R Offline
      reaper7
      @Calin - very nice! tnx
        m5dude @Calin
        @calin
        very nicely done! thanks for sharing sources to learn from
          dda
          Very nice. The speaker noise issue forced me to work out a fix to shut up the speaker on demand, without having to recompile every time. Here's how: you add an end() method in Speaker.cpp:
          void SPEAKER::end() {
            ledcDetachPin(SPEAKER_PIN);
          (declared in Speaker.h)
          class SPEAKER {
            public:
              SPEAKER(void);
              void begin();
              void end();
          Now you can call M5.Speaker.end(); any time to make sure the speaker shuts up. Works with any project – making it a generic solution.
            Calin
            I fixed the speaker noise issue much much easyer.
            Please check the updated version on: https://github.com/botofancalin/M5Stack-ESP32-Oscilloscope
            BTW!!!
            The project is compiled on Visual Studio using the awsome vMicro plugin : http://www.visualmicro.com/
            • dasloloD Offline
              daslolo
              The DSO112A generates signal that's ok clean.
              This M5Stack oscillo graphs something far noisier.
              Why is that? Can this be fixed without lowering the sampling rate by smoothing the analog signal?
              EDIT: I connected to the wrong wires and didn't ground. Once grounded, disconnected USB and pinned to 35, the signal is very clean. Weird that I'd get a squarish signal when connected to AD
              alt text
                Calin
                The maximum voltage on ESP32 ADC can read is 3.3v
                The ESP32 don't have the voltage divider on ADC in as the DSO oscilloscope have.
                Noises can cause high voltage levels, especially near computers, where you have lots of radio waves on different frequency. So even touching the input pin (35) with your hand, the voltage at the input pin can cause more than 3.3v, especially if the ESP is connected to PC by USB cable.
                Some basic filters and voltage dividers at the input pin, can solve that problem.
                dasloloD 1 Reply Last reply Reply Quote 1
                • dasloloD Offline
                  daslolo @Calin
                  @calin and the ESP32 can be damaged by spiked above 3.3V, I read. How do I know if I damaged mine?
                  I'll add voltage divider, is there a way to remove spikes without killing the sensitivity? I am doing an FFT on the signal and don't want to smooth things out too much.
                    Calin
                    If the DAC input was damaged, it won't pick up any signal that you feed to it...
                      Calin
                      Btw... check out the new development: http://forum.m5stack.com/topic/165/m5stack-multiapp-firmware
                      • dasloloD Offline
                        daslolo
                        If I understand this correctly, the ESP32 analog input captures only positive voltage.
                        How do I get the full -/+ range in there?
                          Calin
                          Make a voltage divider with 2 resistors (100k or so...) with one end connected to GND and the other end to 3.3v.
                          The middle of the divider connected to oscilloscope input pin.
                          Apply input signal to input pin and you get +/- 1.65v input range.
                          I designed the code to be used with this divider, that's why, without the divider, the oscilloscope line is at the bottom of the screen.
                          Once you connect the divider, the signal line will be at the middle of the screen just like on a normal oscilloscope.
                          • dasloloD Offline
                            daslolo
                            Without the voltage divider, the amplitude is the same, just offset by 1.65v?
                              Calin
                              The max amplitude is 3.3v. With the divider, the amplitude will be -1.65v to +1.65v (total 3.3v) The aplitude can be solved easy with a series of resistors at the imput. To change the input aplitude, replace the 10K resistor on the example below:
                                pkourany @Calin
                                @calin 在 M5Stack 2 Channel Oscilloscope 中说:
                                he amplitude will be -0.65v to +0.65v (total 3.3v)
                                @calin, I think you meant the input signal range will be -1.65v to +1.65v (total 3.3v). :)
                                  Calin @pkourany
                                  @pkourany 在 M5Stack 2 Channel Oscilloscope 中说:
                                  yes. sorry for typo... edited now :)
                                  • JJJ Offline
                                    JJ @Calin
                                    Awesome oscilloscope case - designed by Macsbug - infos here
                                    • dasloloD Offline
                                      daslolo
                                      • ChrisWRC Offline
                                        ChrisWR
                                        Its restarting every 5 seconds making it useless.. what can be my problem?
                                        ChrisWRC 1 Reply Last reply Reply Quote 0
                                        • ChrisWRC Offline
                                          ChrisWR @ChrisWR
                                          @chriswr Ok solved.. disable the watchdog..
                                          disableCore0WDT();
                                          disableCore1WDT();
