    MicroPython Clock Task with RTC and NTP sync
    6 Posts 5 Posters 26.5k Views 3 Watching
      M5MPy
      Just new to MicroPhyton, I just collected some code pieces in the web to get a "Clock" background task coded with RTC and NTP Sync by just some code lines.
      BTW. No flickering on the display etc.
      Please feel free to comment; need to learn ;-)
      # RTC Clock with NTP Sync for M5STACK
      # References:
      # https://forum.micropython.org/viewtopic.php?t=4329
      # Lobo Version to init RTC and timezone
      # https://forum.micropython.org/viewtopic.php?f=18&t=3553&p=21616&hilit=timezone#p21616
      from m5stack import machine
      from m5stack import lcd
      from time import strftime
      import utime
      import _thread
      # move to lowest line on M5STACK display
      lcd.setCursor(0, 227)
      lcd.setColor(lcd.WHITE)
      lcd.print("RTC Clock 1")
      # initiate rtc
      rtc = machine.RTC()
      print("Synchronize time from NTP server with TZ=Germany ...")
      rtc.ntp_sync(server="hr.pool.ntp.org", tz="CET-1CEST,M3.5.0,M10.5.0/3")
      def watch():
          while True:
              # start position for Date
              if not rtc.synced():                                                            # set color to sync status
                  lcd.setColor(lcd.RED)
              else:
                  lcd.setColor(lcd.GREEN)
      #       lcd.setCursor(92, 227)                                                          # uncomment if you need date on display
      #       lcd.print("Date {}".format(utime.strftime("%Y-%m-%d", utime.localtime())))      # uncomment if needed
              # start position for time only
              lcd.setCursor(213, 227)                                                         # uncomment if date active (see upper lines)
              lcd.print(" Time {}".format(utime.strftime('%H:%M:%S', utime.localtime())))
              utime.sleep(1)
      _thread.start_new_thread ("clock",watch, ())
      1 Reply Last reply Reply Quote 5
      • I Offline
        ItHasU
        Thanks for your example. Where did you found the tz argument ? I cannot find any exhausitive documentation on the function.
          simm
          @ithasu,
          check this link uclibc timezone list
          automation
            M5MPy
            yes, already answered, thanks to @simm
            • f3rn4nd0dF Offline
              f3rn4nd0d
              Just a little comment. I've used this code to have a tiny watch on a M5stick and it did not work till I added the connection to internet. So the code in my case looks like this:
              import wifisetup
              wifisetup.auto_connect()
              from m5stack import *
              from m5ui import *
              and then the rest of the code is similar, changing timezone and whatnot.
              Thanks for the code and best regards / Fernando
                kalon33 @f3rn4nd0d
                @f3rn4nd0d I got "no module named 'wifisetup'" error, and without that, no 'strftime' in time... What am I missing in Mycropython for my M5Stack Gray?
                Thanks for your help.
