    (SOLVED)Power ATOM Lite
    14 Posts 3 Posters 26.1k Views 1 Watching
      cepics
      Hi, how can I power ATOM Lite?
      • m5stackM Online
        use a usb cable then connect to the power bank or computer
          cepics
          tnks
            cepics
            max power consumption?
              cepics
              Can I power Atom from grove and ext pin also?
              • m5stackM Online
                m5stack @cepics
                @cepics yes , you can use grove or ext pin to supply power for Atom. it max power consumption 1.5W
                  cepics
                  tnks a lot
                    Pepsi
                    it is possible via the ext pin for 5 volt or also the ext pin for 3.3 volt? (not using the Grove port)
                    • m5stackM Online
                      @pepsi
                      you can see the sticker , the ext pin provided a 5V input pin. the ext Pin 3.3V only can output.
                      0_1586423495012_c5e3b7ac-f9ee-4e75-9149-d7a3791ec99a-image.png?width=300
                        cepics @m5stack
                        @m5stack We are talking about M5Atom here....
                          Pepsi
                          my question is indeed related to the Atom. the symbols on the sticker for the Atom only hold 3V3 and 5V not no arrow if it is input/output.
                          I'm looking for a project with the Atom to run off a LiPo battery.
                          A step down converter will work longer than a step up converter.
                          I know the M5StickC (i have a few), but i need a more robust power switch. and the stick does not have a breakout option for a switch.
                          • m5stackM Online
                            m5stack @cepics
                            @cepics ....sorry ...i placed the wrong picture。 but they pin function is same. 5V can input/out put. 3.3V can only output
                            • m5stackM Online
                              m5stack @Pepsi
                              @pepsi ATOM ext Pins. 5V can input/out put. 3.3V can only output
                                Pepsi
                                thank you.
