    MicroPython Firmware with M5Stack libraries
    11 Posts 6 Posters 32.4k Views 3 Watching
      REPL works with the stock UIFlow firmware (to a degree)
      You will need a command line tool to install python libs.
      For more information on this take a look in the Blynk UIFlow discussion.
        alexruf @ajb2k3
        What exactly do you mean with 'Blynk UIFlow discussion'?
          ajb2k3 @alexruf
          @alexruf said in MicroPython Firmware with M5Stack libraries:
          sorry forgot the link to the discussion
          http://community.m5stack.com/topic/575/blynk-on-m5stack-via-uiflow-and-block-maker/14
          • world101W Offline
            world101
            If you want to use a basic MicroPython firmware without all the bloat (preloaded apps/games, etc.) and CloudIDE (i.e. uiFlow) stuff that comes with the stock firmware, you should try this repo:
            https://github.com/m5stack/M5Stack_MicroPython
            Or you could give this one a try as well:
            https://github.com/tuupola/micropython-m5stack
            A ajb2k3A J 3 Replies Last reply Reply Quote 0
              alexruf @world101
              @world101
              Thanks! This is exactly what I was looking for.
                ajb2k3 @world101
                @world101
                Interesting, may have to try that on one of mine
                  jhfoo @world101
                  @world101 is there one for M5StickC? The sample codes are for the larger model.
                  • world101W Offline
                    world101 @jhfoo
                    @jhfoo said in MicroPython Firmware with M5Stack libraries:
                    Not to my knowledge. You would need to flash the m5stickC with the standard MicroPython firmware (see this link) then manually import whatever m5stickC libs you want to use from here.
                    • lukasmaximusL Offline
                      The theme of this weeks video will be on this subject, if your patient you can wait until Friday and there will be a full video on it. Otherwise check out this repo if you know what your doing https://github.com/lukasmaximus89/M5Stick-C-Micropython-1.12
                        tialm
                        Hi @lukasmaximus ! Any idea on when an updated version of the micropython m5stack libraries will be available? Since the ones in here are not complete, and don't if they are up to date with the current version used in uiflow
