    Micropython AWS IoT connect/add files to UI Flow?
    2 Posts 2 Posters 5.7k Views 1 Watching
      kgobes
      I'd like to connect my M5StickC to AWS IoT via the UIFlow web console. The MQTT broker block on UIFlow doesn't have the options to include a certificate file needed to connect, so the Micropython tab seems like the only option. However, I don't see a way to upload files to the IDE for the certificates- I could perhaps create them in the code but I'm not sure if that's the best option. Any suggestions? Thanks!
      • lukasmaximusL Offline
        I assume you'll want to put the certificate in the flash. there are various ways you can transfer files to the flash, check this video on how to do so
        https://www.youtube.com/watch?v=bdyZx2KC54Y
