    M5StickC and 18650C hat problem
    1 Posts 1 Posters 4.0k Views
    • O Offline
      OS88
      I am using M5StickC and 18650C hat together and encountering a weird issue.
      First, when assembling them to each other with the designated screws, it seem to disrupt the on/off button or something because it can't be pressed after wise, and maybe related to the fact that my code suddenly gets stuck for no reason.
      This is my code(basically I expected to see led on while it is not in sleep mode):
      #include <WiFi.h>
      #include <M5StickC.h>
      #include "arduino_secrets.h"
      char *ssid[] = { SECRET_SSID1 , SECRET_SSID2 , SECRET_SSID3 , SECRET_SSID4 , SECRET_SSID5 };
      char *pass[] = { SECRET_PASS1 , SECRET_PASS2 , SECRET_PASS3 , SECRET_PASS4 , SECRET_PASS5 };
      //#define TIME_TO_SLEEP_SECONDS 3600
      #define TIME_TO_SLEEP_SECONDS 60
      const int LED = 10;
      int sm;
      String deviceID;
      bool sentData = false;
      M5_Setup();
      wifiTask();
      wifiTask();
      M5.update();
      getSm();
      if(sentData)
      Serial.println("Going to sleep, good night");
      Serial.flush();
      delay(3500);
      M5.Axp.DeepSleep(SLEEP_SEC(TIME_TO_SLEEP_SECONDS));
      loopAnalysis();
      void getSm() {
      #define SMPIN 33
      float smVal = analogRead(SMPIN);
      float smFloat = smVal * 0.01 + (float) sm * 0.99;
      sm = (int) smFloat;
      int httpRequest() {
      static WiFiClient client;
      static const char WEBSITE[] = "api.pushingbox.com";
      static const String devid = "v2928F6149137678";
      client.stop();
      if (client.connect(WEBSITE, 80)) {
      Serial.println("connecting...");
      client.print("GET /pushingbox?devid=" + devid
      + "&deviceID=" + (String) deviceID
      + "&sm=" + (String) sm
      client.println(" HTTP/1.1");
      client.print("Host: ");
      client.println(WEBSITE);
      client.println("Connection: close");
      client.println();
      Serial.println("Sent data");
      sentData = true;
      return 1;
      } else {
      Serial.println("failed to connect to http");
      return 0;
      void wifiTask() {
      static int state = 0;
      static int wifiConnectTry = 0;
      static int wifiRestartTry = 0;
      static int network = 0;
      static int wifiStatus = WL_IDLE_STATUS;
      static int httpStatus = 0;
      static int httpConnectTry = 0;
      static unsigned long previousMillis = 0;
      unsigned long currentMillis = 0;
      #define WIFI_CONNECT_TIMEOUT 10000 // seconds waiting between re-connection attempts
      #define HTTP_CONNECT_TIMEOUT 5000
      #define HTTP_CONNECTED 1
      #define HTTP_DISCONNECTED 0
      enum WIFI_STATE_TYPE { WIFI_CONNECT,
      HTTP_CONNECT,
      HTTP_POLL,
      WIFI_STATE_RESTART = 255
      switch ( state )
      case WIFI_CONNECT:
      if ( wifiStatus == WL_CONNECTED )
      Serial.println("WIFI Connected");
      printWifiStatus();
      state++;
      digitalWrite( LED , LOW );
      break;
      if ( millis() - previousMillis < WIFI_CONNECT_TIMEOUT && wifiConnectTry > 0 )
      break;
      if ( wifiConnectTry > 9 )
        state = WIFI_STATE_RESTART;
        break;
      if ( wifiRestartTry > 1 )
        wifiRestartTry = 0;
        network++;
        if (network == 5) {
          network = 0;
        Serial.println( "Switched to network: " + String(network));
        break;
      wifiStatus = WiFi.begin( ssid[network], pass[network] );
      previousMillis = millis();
      wifiConnectTry++;
      Serial.print( "Try: " );
      Serial.print( wifiConnectTry );
      Serial.print( " Status: " );
      Serial.println( wifiStatus );
      break;
      case HTTP_CONNECT:
      if (httpStatus == HTTP_CONNECTED) {
      state++;
      break;
      if ( millis() - previousMillis < HTTP_CONNECT_TIMEOUT && httpConnectTry > 0 )
      break;
      if ( httpConnectTry > 10 )
        break;
      httpStatus = httpRequest();
      httpConnectTry++;
      Serial.print( "http Try: " );
      Serial.print( httpConnectTry );
      Serial.print( " http Status: " );
      Serial.println( httpStatus );
      break;
      case HTTP_POLL:
      if (httpStatus == HTTP_DISCONNECTED) {
      if (WiFi.status() == WL_CONNECTED) {
      state = HTTP_CONNECT;
      break;
      else {
      break;
      break;
      default:
      state = 0;
      wifiConnectTry = 0;
      httpConnectTry = 0;
      httpStatus = HTTP_DISCONNECTED;
      WiFi.disconnect();
      Serial.println( "WiFi restart" );
      wifiRestartTry++;
      break;
      void printWifiStatus() {
      static byte mac[6];
      Serial.print("SSID: ");
      Serial.println(WiFi.SSID());
      IPAddress ip = WiFi.localIP();
      Serial.print("IP Address: ");
      Serial.println(ip);
      long rssi = WiFi.RSSI();
      Serial.print("signal strength (RSSI):");
      Serial.print(rssi);
      Serial.println(" dBm");
      WiFi.macAddress(mac);
      String mac0,mac1,mac2,mac3,mac4,mac5;
      mac0 = String(mac[0],HEX);
      mac1 = String(mac[1],HEX);
      mac2 = String(mac[2],HEX);
      mac3 = String(mac[3],HEX);
      mac4 = String(mac[4],HEX);
      mac5 = String(mac[5],HEX);
      deviceID = String(mac5 + ":" + mac4 + ":" + mac3 + ":" + mac2 + ":" + mac1 + ":" + mac0);
      Serial.print("mac address: "); Serial.println(deviceID);
      void loopAnalysis()
      static unsigned long lastMillis = 0;
      static unsigned long minLoopTime = 0xFFFFFFFF;
      static unsigned long maxLoopTime = 0;
      static unsigned long loopCounter = 0;
      #define INTERVAL 1000
      unsigned long currentMillis = millis();
      if ( currentMillis - previousMillis > INTERVAL )
      Serial.print( "Loops: " );
      Serial.print( loopCounter );
      Serial.print( " ( " );
      Serial.print( minLoopTime );
      Serial.print( " / " );
      Serial.print( maxLoopTime );
      Serial.println( " )" );
      previousMillis = currentMillis;
      loopCounter = 0;
      maxLoopTime = 0;
      loopCounter++;
      unsigned long loopTime = currentMillis - lastMillis;
      lastMillis = currentMillis;
      if ( loopTime < minLoopTime )
      minLoopTime = loopTime;
      if ( loopTime > maxLoopTime )
      maxLoopTime = loopTime;
      void M5_Setup() {
      M5.Axp.ScreenBreath(0);
      pinMode(LED,OUTPUT);
      digitalWrite(LED,LOW);
      Thanks!
