    M5Atom Matrix crashing: can't use
    matrixcrasharduino ide
    7 Posts 3 Posters 15.3k Views 1 Watching
      FunkyFab
      Dear all,
      I have a M5Atom Matrix, and using Arduino IDE to program it.
      Last sketch I wrote was faulty, and now, the M5Atom Matrix is crashing as soon as its plugged in.
      As a consequence, the serial port opens, and closes immediately, which makes it impossible to connect to in order to load a different sketch.
      How can I deal with that?
        Hi FunkyFab
        normally when that happens I connect GPIO0 to GND and then connect power to force the ESP32 into download boot mode. However GPIO0 doesn't seem to be exposed on the M5Atom. Maybe GPIO0 is at least connected to an internal test point on the PCB inside the M5Atom? I am only guessing here as I don't own a M5Atom.
        Good luck.
        • m5stackM Offline
          hi, you could try these way
          long press the reset button when you upload the sketch. when you see the log start uploading.. release the button or try to use another USB Port.
            FunkyFab @m5stack
            @m5stack: thanks. According to the Arduino IDE, it's flashed. However, despite the fact that I use a very simple sketch from the examples (WifiScan), it's still crashing.
            My Board is correct (M5StackCore-ESP32), my upload speed is 115200, flash frequence 80 MHz, flash mode QIO, partition scheme Default (also tried NO OTA).
            The serial monitor shows some output from the board, but unintelligible (I've tried all the possible baud values).
            Is there any option that I've missed ?
            Regards
            m5stackM F 2 Replies Last reply Reply Quote 0
            • m5stackM Offline
              m5stack @FunkyFab
              @funkyfab not. use ATOM you should select M5StickC or ESP32 Pico board. upload speed setup 1.5M or 115200
                FunkyFab @FunkyFab
                @funkyfab : had to flash with DIO mode once.
                  Hi FunkyFab
                  interesting... Thanks for sharing. Glad you got it working again.
                  Cheers
