    M5 Fire "get battery level" block
    Scheduled Pinned Locked Moved M5Stack Fire
    11 Posts 4 Posters 16.1k Views 1 Watching
      F3l1x
      Hi
      I'm getting started with the M5 Fire and UI Flow
      I am trying to print the battery level using the "get battery level" block
      I get an awful red ERROR message with "name 'power' isn't defined"
      The code is
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import time
      label0 = M5TextBox(262, 204, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
      BatLvl = None
      while True:
      BatLvl = power.getBatteryLevel()
      label0.setText(str(BatLvl))
      speaker.sing(147, 1)
      wait(1)
      I thought power was part of the library... If not, what is the correct way of defining it ?
        Have you updated the fire to the latest UIFlow Firmware?
          F3l1x
          Yes I thought I should update...unfortunately, M5burner does not work on my Windows laptop
          "Error loading Python DLL 'C:\Users\xxx\AppData\Local\Temp_MEI97002\python36.dll'.
          LoadLibrary: The specified module could not be found.
            robalstona
            Try install Python 3.6 or higher for windows. Then burner software should work without errors.
              F3l1x
              python36.dll DOES exist on my computer
              Is there a way to give it's path to M5burner as a parameter? (I tried adding python36.dll to the Windows PATH, with no luck)
                robalstona
                Find a file esptool.exe and copy this dll to the same folder.
                  F3l1x
                  I already added python36.dll to the M5burner folder on my computer.
                  Using esptools, where do I need to add python36.dll ?
                    robalstona
                    i download M5Burner in zip file. When i unpack it i has tools folder which include esptool. Copy dll file in this folder. Eventually find downloaded firmware files in firmwares folder and burn it with other flash tools like esp flash tool from espressif home page
                      F3l1x
                      Hi again
                      I tried M5burner on another laptop
                      It "sees" the M5 fire but cannot flash it
                      "A fatal error occurred: File fatfs_image_0x370000.bin (length 2678784) at offset 3604480 will not fit in 4194304 bytes of flash. Use --flash-size argument, or change flashing address."
                      Weird, as the firmware is meant for the fire hardware, it should match its memory size ?!
                      • m5stackM Online
                        m5stack @F3l1x
                        @f3l1x could you try erase the flash then burn the firmware again?
                          F3l1x
                          I did erase, and M5Burner did never complain but it didn't solve the problem
                          I don't know why but as I tried again and again, it worked...pretty weird...
