@teastain Thank you for your tip! After activating USB CDC for Boot to - Enable the Serial.print() worked as it should. /BoM_M5
B
Offline
RE: Why is the Serial.print() not working in the M5NanoC6 unit?
Why is the Serial.print() not working in M5NanoC6 controller?
M5 Burner and MacBook Pro
I am using M5Stack Core2 and a Macbook Pro (Intel). After installing the Serial port drivers for M5Burner I can not establish contact between the M5 Core2 and the M5Burner via the USB port cable. The Error message is:
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing crun at: /Library/Developer/CommandLineTool....
My communication with Arduino IDE is working very well.
Can someone perhaps please assist me to establish connection with M5Burner.
