Hello, I have a standard Echo Atom with the Home Assistant firmware. I’d like to mount this on the Echo Pyramid, but the Pyramid’s instructions only show an example for the S3 Atom. Unfortunately, the setup isn’t working in ESP Home—the GPIO and PSRAM settings don’t match. I just want to use the audio through the Echo Pyramid. A firmware in M5Burner flashe the Atom so that it becomes a Bluetooth speaker, which doesn't help me. But it seems to be compatible. Does anyone have the correct code?
D
Offline
Echo Atom and Echo Pyramid Not working with Home Assistant
