@kuriko Thank you for your response. I did this step by step. Deleted record.json res.json After pushing the code, the problem remains the same., error 403 So I Reburn the Core2. After pushing the code, the problem block on Sync screen, error 403 I think there is a problem accessing the file bucket on Alibaba. Or else the load transmitted by mqtt to the device is not what is expected for res and record json. Similar of: https://community.m5stack.com/topic/7652/uiflow-2-0-sync-error
