@DocDatenschutz I did some reading and it seems that the Cardputer Adv handles the keyboard differently then on the Cardputer, meaning older firmware is unable to sense keyboard input. As far as I am aware, there is no current fix for this issue besides getting new firmware made for the Adv, though it seems like they are currently trying to fix the issue.
O
Offline
RE: Cardputer ADV Noobie
@DocDatenschutz I am also a new user, and I have been having the same issue with Doom, though not the crashing. I do not know how to fix the issues myself, but until someone else comes to help, I thought I should recommend installing M5Launcher, as it allows you to install new firmware from the internet and not have to plug into to M5Burner every time, as well as install firmware onto an SD card so that you can install new firmware from the SD card. I would also recommend installing Bruce, which gives you a lot of useful tools in one file, instead of having to install new firmware from each. Installing M5launcher may fix crashing, though I don't really know as it was the first thing I installed when I got mine.
