@felmue ok, but is the battery always have to be swapped every time it’s faulty?
RE: Tab5 RTC backup battery specifications
@easytarget, I found out where’s the battery in the schematics pdf, but it doesn’t say what is the battery type
My project that I am currently making with the Tab5: Project_R001
This is one of the projects that is really admirable to me, Alongside with The Tab5 upgrade since July 2025, which involves every feature i needed! Obviously the Microphone only for the AI interaction, and Speaker for the music from the SD card. I also used M5Unified for the hardware, it is very easy to use and understand. I also achieved milestones such as making a fully functional file system, making the Tab5 run on LVGL 9.3 (Before LVGL 9.4) the month after I got the Tab5. I am now currently making a Raspberry Pi 5 server for the AI, AI inferencing, etc. I will also release the project's source code over github, so you can make the same for you too! But if you want to use a raspberry pi, you can use V0.3.0-R4 till V1.0, if not, you can wait until V1.0. Hope you have a great day!
