    AXP192 library SetChargeCurrent in M5StickC but not in M5StickCPlus
    2 Posts 2 Posters 2.9k Views
      kazokutchi
      I'm using M5StickCplus and BugC for my project.
      We some how made a automatic charging system with a wireless pads.
      But charging time takes quite long, and I found "SetChargeCurrent" but only in M5StickC, not Plus.
      Just moving library file doesn't work.
      Is there any register reference?
      or plan to get this SetChargeCurrent back?
      Thank you for reading.
      • felmueF Online
        Hello @kazokutchi
        From below comment I assume M5Stack engineers decided to not include the SetChargerCurrent() function for M5StickCPlus.
        // Not recommend to set charge current > 100mA, since Battery is only 80mAh.
        // more then 1C charge-rate may shorten battery life-span.
        That said, have you tired to only copy the function by itself into the corresponding AXP192.cpp file of the M5StickCPlus library?
