    AXP192 library SetChargeCurrent in M5StickC but not in M5StickCPlus
    2 Posts 2 Posters 2.9k Views
      kazokutchi
      I'm using M5StickCplus and BugC for my project.
      We some how made a automatic charging system with a wireless pads.
      But charging time takes quite long, and I found "SetChargeCurrent" but only in M5StickC, not Plus.
      Just moving library file doesn't work.
      Is there any register reference?
      or plan to get this SetChargeCurrent back?
      Thank you for reading.
        Hello @kazokutchi
        From below comment I assume M5Stack engineers decided to not include the SetChargerCurrent() function for M5StickCPlus.
        // Not recommend to set charge current > 100mA, since Battery is only 80mAh.
        // more then 1C charge-rate may shorten battery life-span.
        That said, have you tired to only copy the function by itself into the corresponding AXP192.cpp file of the M5StickCPlus library?
