M5.Axp.ScreenBreath() hangs when used in interrupt
It seems that M5.Axp.ScreenBreath() hangs when it is used in a interrupt.
The demo below should turn off the screen after a timer delay and turn it back on when the button is pressed. Run it in Arduino IDE.
On my system, this program crashes with a watchdog timeout during i2c operation. See it in serial log.#include <M5StickC.h> #define BUTTON_MAIN 37 //The main button pin number #define SCREEN_TIMEOUT 10 //Screen-off timeout in seconds hw_timer_t *timer; //Screen-off timer void IRAM_ATTR onButton() { //Interrupt on button press => turn on the screen detachInterrupt(BUTTON_MAIN); //Ignore more button presses M5.Axp.ScreenBreath(10); //Set screen light ON timerAlarmEnable(timer); //Start timer for screen-off delay } void IRAM_ATTR onTimer(){ //Interrupt on timer => turn off the screen timerAlarmDisable(timer); //Stop the timer. M5.Axp.ScreenBreath(0); //Set screen light OFF attachInterrupt(BUTTON_MAIN,onButton,FALLING); //Attach interrupt on button press => turn on the screen } void setup() { M5.begin(); //Init M5. Start with screen ON. M5.Lcd.fillScreen(YELLOW); //Make screen yellow pinMode(BUTTON_MAIN, INPUT_PULLUP); //Button GPIO set as input, pull-up enabled timer=timerBegin(1,40000,true); //Init screen light timer, divisor 40000 => 0.5ms steps timerAttachInterrupt(timer,&onTimer,true); //Set screen light timer interrupt function timerAlarmWrite(timer,SCREEN_TIMEOUT*2000,true); //Set interrupt to turn off screen after X timer steps of 0.5ms each. timerAlarmEnable(timer); //Start timer for screen-off delay } void loop() { //No code here. }
