    95 Posts 22 Posters 745.0k Views 10 Watching
    • B Offline
      bobolink
      I really like M5ez so I gave it its own core. Justified it by saying that’s real MVC architecture! Real Computer Science stuff.
      GLOBAL INFO
      core 0 is the communications processor.
      Uses the ESP-NOW protocol
      on the 2.4 GHz radio
      This process runs as a task created
      on core 1
      core 1 is the UI processor.
      Maintains the M5Stack M5ez LCD menu
      Runs Arduino setup() and loop()
      Use RTOS semaphores when accessing the global vars to/from the local versions.
        macle
        Is there a chance to change font (or size) of ez.header ?
        Regards, M
          mawg
          Looks great! Does it play well with PlatformIO ?
          • m5stackM Online
            Great Job
              @Rop is M5EZ supporting the Stick C?
              I have had a query from the Facebook group.
              • RopR Offline
                Rop
                No it does not: it only works on the 3-Button M5Stack devices.
                  ajb2k3 @Rop
                  @rop Any intention of a stick version?
                  • asalazaroA Offline
                    asalazaro @BrianR
                    @brianr @rop Hey guys, thanks a lot for this very elegant solution, I´m using the ezMenu library in a program where I had installed Blynk working very well but everytime when I activated the ezMenu with mainmenu.run(); my Blynk app was very unstable, with the trick of ez.addEvent(run_Blynk) in the setup() function now is working very well, thanks for the help
                      hobo
                      great project.
                      It is possible to use the face encoder for up, down and enter?
                      if yes, you have an example?
                      this will be great
                        hobo
                        • G Offline
                          GSAL
                          It is great using the M5EZ!
                          But I want / need to give my Core a static IP address. Is there an easy way to alter the Wifi settings menu and add the option of adding static ip? Maybe In such a way it is stored in the preferences?
                          kr, G
                            kilam
                            I wanted to know if there is a way to use faces keyboard in the menus (i.e. I have the calculator keyboard and instead of using the three buttons to go up and down and select, I want to use the keys on the face, for example for selecting first line I will type on the key '1' and so on).
                            and if it is possible, can you give me an example of code using it.
                              AndyT
                              How do i get the characters for my region such as the pound sign £ ?
