    95 Posts 22 Posters 732.0k Views 10 Watching
      macle
      Is there a chance to change font (or size) of ez.header ?
      Regards, M
        mawg
        Looks great! Does it play well with PlatformIO ?
        • m5stackM Offline
          Great Job
            @Rop is M5EZ supporting the Stick C?
            I have had a query from the Facebook group.
            • RopR Offline
              Rop
              No it does not: it only works on the 3-Button M5Stack devices.
                ajb2k3 @Rop
                @rop Any intention of a stick version?
                • asalazaroA Offline
                  asalazaro @BrianR
                  @brianr @rop Hey guys, thanks a lot for this very elegant solution, I´m using the ezMenu library in a program where I had installed Blynk working very well but everytime when I activated the ezMenu with mainmenu.run(); my Blynk app was very unstable, with the trick of ez.addEvent(run_Blynk) in the setup() function now is working very well, thanks for the help
                    hobo
                    great project.
                    It is possible to use the face encoder for up, down and enter?
                    if yes, you have an example?
                    this will be great
                      hobo
                      • G Offline
                        GSAL
                        It is great using the M5EZ!
                        But I want / need to give my Core a static IP address. Is there an easy way to alter the Wifi settings menu and add the option of adding static ip? Maybe In such a way it is stored in the preferences?
                        kr, G
                          kilam
                          I wanted to know if there is a way to use faces keyboard in the menus (i.e. I have the calculator keyboard and instead of using the three buttons to go up and down and select, I want to use the keys on the face, for example for selecting first line I will type on the key '1' and so on).
                          and if it is possible, can you give me an example of code using it.
                            AndyT
                            How do i get the characters for my region such as the pound sign £ ?
