    How to use CAN UNIT
    3 Posts 3 Posters 5.1k Views
    • ryokurta256R Offline
      ryokurta256
      I got a CAN UNIT that connects with the GROVE interface.
      When I tried the code linked below in the test, it worked on M5Stack Fire, but not on M5Stack Basic.
      I assigned the TX and RX settings to GROVE PORTA.
      It worked with this content on Fire.
      I also confirmed it with M5Stic-C, but it still did not work.
      Are there any settings that I have forgotten?
      https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/CAN
      • G Offline
        gschora @ryokurta256
        @ryokurta256 Did you solve this? I'm having the same trouble with the M5Tough. It works on the Fire but not on the Tough...
        • m5stackM Online
          did you have to add a terminal resistor between the H and L lines?
