    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 146.7k Views 2 Watching
      Richard
        Richard
        m5stack from m5stack store
          Richard
            Calin
            Here is the test using your code (with small modifications and relevant comments)
            and standard m5Stack library from PlatformIO:
            And here is the result:
              Richard
              fine, but does not work on ide arduino.
              can you send me your code in espi setup?
                Richard
                do you have tested my with arduino ide?
                thank you
                  Richard
                  i have install PlatformIO and load my projet:
                  Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                  Hash of data verified.
                  Leaving...
                  Hard resetting via RTS pin...
                  ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                  I still have the problem!
                  hardware problem?
                  I
                    Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                      Calin @Richard
                      @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                      I use Visual Studio, Eclipse or PlatformIO.
                      I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                      The M5Stack library is already installed local into project.
                      All you have to do is to download the repository and compile the code.
                        ajb2k3 @Calin
                        @calin 在 drawJpgFile / drawBmpFile 中说:
                        Maybe a stupid question (or two) but I'm going to ask anyway.
                        Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                        Is there a specific image limitation for the image?
                          Richard
                          I use Visual Studio too.
                          i have just tested your programm and i still have the problem.
                          I think it's a hardware problem.
                          I'm waiting for another device
                          Thank you.
                            Calin @Richard
                            @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                            I think there is no limitation on card size.
                            There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                            As i know, the cards formatted as FAT32 are preffered.
                            @richard 在 drawJpgFile / drawBmpFile 中说:
                            Thank you.
                            That problem can be caused by the ILI9341 controller from the TFT.
                            If that is the case, the only solution is a replacement.
                              Richard
                              I use a SD 4mo FAT32
                                Richard
                                and also
                                I tested with a 32mo
                                  I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                                  How do I tell if I have the ILI9341?
                                    Calin @ajb2k3
                                    @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                                      Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                                      I had to reduce the image to a 256bit Indexed image!
                                        Richard
                                        I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                                        It works very well.
                                        The first M5stack doesn't work propely.
                                        I hope the M5stack store will change it.
                                          Richard
                                            Richard
                                            Thank you Calin!
