    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 146.7k Views 2 Watching
      Richard
      do you have tested my with arduino ide?
      thank you
        Richard
        i have install PlatformIO and load my projet:
        Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
        Hash of data verified.
        Leaving...
        Hard resetting via RTS pin...
        ====================================================== [SUCCESS] Took 23.68 seconds =======================================
        I still have the problem!
        hardware problem?
        I
          Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
            Calin @Richard
            @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
            I use Visual Studio, Eclipse or PlatformIO.
            I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
            The M5Stack library is already installed local into project.
            All you have to do is to download the repository and compile the code.
              ajb2k3 @Calin
              @calin 在 drawJpgFile / drawBmpFile 中说:
              Maybe a stupid question (or two) but I'm going to ask anyway.
              Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
              Is there a specific image limitation for the image?
                Richard
                I use Visual Studio too.
                i have just tested your programm and i still have the problem.
                I think it's a hardware problem.
                I'm waiting for another device
                Thank you.
                  Calin @Richard
                  @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                  I think there is no limitation on card size.
                  There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                  As i know, the cards formatted as FAT32 are preffered.
                  @richard 在 drawJpgFile / drawBmpFile 中说:
                  Thank you.
                  That problem can be caused by the ILI9341 controller from the TFT.
                  If that is the case, the only solution is a replacement.
                    Richard
                    I use a SD 4mo FAT32
                      Richard
                      and also
                      I tested with a 32mo
                        I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                        How do I tell if I have the ILI9341?
                          Calin @ajb2k3
                          @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                            Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                            I had to reduce the image to a 256bit Indexed image!
                              Richard
                              I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                              It works very well.
                              The first M5stack doesn't work propely.
                              I hope the M5stack store will change it.
                                Richard
                                  Richard
                                  Thank you Calin!
