    M5Stick C 'http GET'
    6 Posts 3 Posters 12.8k Views
    • I Offline
      ianlyonthomas
      I am using M5Stick C and have put together a blocky which is a simple http GET process.
      i.e. connect to WiFi and send data via GET.
      The Data (Key&Value) is populated and the solution successfully sends to the correct URL but...
      No data is being included in the URL sent.
      On checking the Python code, the data is not added.
      Is this a bug?
      Python code generated via Blocky is below and I can provide .m5f if required.
      Ian
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import wifiCfg
      import urequests
      setScreenColor(0x111111)
      wifiCfg.doConnect('XXXXXXXX', 'XXXXXXXXX')
      label0 = M5TextBox(0, 16, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      label1 = M5TextBox(0, 55, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      if wifiCfg.wlan_sta.isconnected():
      label1.setColor(0x3333ff)
      label1.setFont(lcd.FONT_DejaVu18)
      label1.setText('connected')
      try:
      req = urequests.request(method='GET', url='http://URL.com/insertGet.php', headers={})
      label1.setText('SENT')
      label0.setColor(0x33ff33)
      label0.setFont(lcd.FONT_DejaVu18)
      label0.setText(str(req.status_code))
      except:
      pass
      else:
      label1.setColor(0xff0000)
      label1.setText('NOT SENT')
        mb
        Within Python it seems there are no parameters set.
        You can add them in Blockly at Advanced -> Http -> Http Request -> Data with a Map?
        Can you provide a screenshot? (If you need an image upload service, use imgpile.com or similar)
        • I Offline
          ianlyonthomas
          Sorry, I was not clear.
          Within Data>Create Map, I have added key: Temperature, Value:30 and key:Humidity, Value:50
          These are not present within the Python code.
          I will upload an image of the blocky.
          Ian
          • I Offline
            ianlyonthomas
            For blocky screen shot https://imgpile.com/i/798bPr
            • sodokuS Offline
              sodoku
              It ignores the data when using "GET", if you set it to e.g. "POST" the python code includes the data.
              • I Offline
                ianlyonthomas
                Bit confused as to why the 'Data' is ignored in GET.
                Switched to POST but data is still not delivered. I will continue to test and se if I can isolate issue.
